VIN Decode please
Old Dec 17, 2017 | 12:27 PM
Capjack01's Avatar
Capjack01
VIN Decode please
what I know about the truck ('66 F-250 4.9L inline 6) I'm working on is it was formerly a fleet truck for SDG&E (our local gas/electric supplier here in San Diego). the last owner bought it from the company where he worked at the time.
from what I can tell, its still pretty much what it was built to be originally (except for some of the more creative 'fixes' the last owner performed).
other than that, I know little about it. I wanted to see if the tag showed anything interesting and you all have a lot more info than I do.
Old Dec 17, 2017 | 03:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Capjack01
F25 = F250 2WD
B = 300 1V I-6.
R = San Jose CA Assembly Plant.
873083 = 1966.
129" Wheelbase.
COLOR: Blank.*
F253 = F250 2WD, 6,000 lbs. GVWR
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
G = C4 Automatic Transmission.
24 = Dana 60 Rear Axle / 4.10-1 / 5,200 lbs. Rear Axle Capacity.
6,000 lbs. Gross Vehicle Weight Rating.
150 net HP @ 3,600 RPM
713104:
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
3104 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
*When there is no COLOR code stamped on the Warranty Plate, truck painted a non standard color per the original purchasers order.
This makes the truck a Domestic Special Order.
Old Dec 17, 2017 | 03:53 PM
Capjack01's Avatar
Capjack01
fantastic. thanks a ton Numbers.
Old Dec 19, 2017 | 10:21 AM
Capjack01's Avatar
Capjack01
another question regarding this truck. I recently had to replace the radiator. the old one was too far gone to repair cheaply. by far it was less expensive to order a new one.
after 2 tries at the local Auto parts store (and being given two incorrect radiators to start with) it was determined the radiator required is a large brass Heavy Duty F-250/F-350 radiator (vs the other two std duty, narrow aluminum/plastic replacement versions).
at some point it also seems someone installed a Thunderbird style divorced power brake booster. so, with that, what other HD parts might have been installed on/should I look for on these fleet trucks?
Christmas
Dec 3, 2018 07:10 PM
dreamofford
Aug 13, 2017 09:53 AM
MagicNewswire
Jul 5, 2016 09:12 AM
Nose is
Jun 5, 2015 03:56 PM
The Boss
Oct 14, 2014 02:25 PM
