Help with mounting Reese hitch adaptor into OEM puck system for 2017 F350
Anyone have any advice on getting the Reese OEM hutch adaptor set into the OEM puck system. I can get it dropped into the pucks correctly but none of the levers will turn in to lock into place. It seems like maybe the locking bolts need to be turned the lengthen the locks so they drop in low enough to get in and under the pucks. Hopefully that makes sense to someone who knows about this. Thanks in advance.
I remember spending quite a bit of time adjusting. 2 would go, 2 would not. Back & forth several times until they were at the point senix mentions. Not too hard to lock on, but no slop either. It was not an enjoyable experience.
This is if you're speaking about the so called "window frame" type adapter.
jtexfisher
08-28-2015 02:29 PM
