Splash Sheild behind Radiator Torn.
Old Dec 16, 2017 | 07:57 AM
Aftrmidnite's Avatar
Aftrmidnite
I had the Truck safety inspected, and it passed. The mechanic made note and
showed me the splash shield behind the radiator was torn, and should be repaired or replaced. Does anyone know what this part is or its purpose?
2017 F-150 XLT FX4
Old Dec 18, 2017 | 09:35 PM
msgtord's Avatar
msgtord
It's for airflow. Most folks just pull it out and toss it. If mine tears anymore I'll replace it. It's cheap.
Old Apr 22, 2018 | 05:18 PM
Aftrmidnite
I repaired it, after figuring out two hoses would have to be removed to replace it. Bought a Sheet of 12" X 12" x 3/32" Reinforced Neoprene Rubber from McMaster Carr.. Cut an ample Patch to fit where the tab is. Glued it on the smooth side, "Up Side," of the Shield by doubling up on the contact cement, and reused the plastic rivet. I also had to glue it on the right side. I may put a patch on that side, however I can't put the patch on the smooth side.
Padilla Shore
1947 and Older Ford Trucks
Mar 23, 2018 08:00 AM
52 USCG Panel
35
May 13, 2016 05:29 PM
old409
Jun 10, 2015 09:01 AM
lemonshindig
Dec 4, 2013 09:13 PM
