2003 2WD leveling Kit
Old Dec 14, 2017 | 08:13 PM
mchall74's Avatar
mchall74
Hello all I recently bought a 2003 Crew cab 7.3 2WD truck, the guy i bought it from had purchased 2.5" Nylon front leveling kit with stud extenders. My mechanic put them on yesterday and advised that i needed to get it aligned as the Camber is way out. So i set an appointment with my local Boulevard Tire to do the alignment with camber kits. I drop it off and get a call 30 mins later they put it on the rack and tell me that there is no way they can get the camber kits to fix the issue. The guy tells me that i need I-beam brackets.
I have searched everywhere for these brackets for a 2wd truck and I cannot find them anywhere?
So my question is has anyone else had problems with these 2.5" spacer lift kits from ebay? I only wanted the level look as the front is so low on these 2WD's.
I really just need help figuring out a work around or should I go to a different alignment shop?
Old Dec 14, 2017 | 08:48 PM
Colorado350's Avatar
Colorado350
I've been looking at this kit for a long time. If you read the description it tells you need aftermarket Camber Eccentrics. Available at NAPA Hope this helps!
FORD F250 F350 SUPER DUTY 2WD 2" LEVELING LIFT KIT- FB2 HC https://www.ebay.com/i/121836239625
Old Dec 14, 2017 | 09:09 PM
z31freakify's Avatar
z31freakify
Here ya go
https://m.ebay.com/itm/MOOG-Front-RW...cAAOSwCOpZd~A3
Old Dec 14, 2017 | 10:33 PM
timmyboy76's Avatar
timmyboy76
Can't think of the member, but he installed HD springs on his 2wd, which leveled it out. Came out looking bada$$
Old Dec 15, 2017 | 07:13 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Originally Posted by mchall74
So my question is has anyone else had problems with these 2.5" spacer lifts?
We used a 2.5” spacer and got new springs. The two gave us about 4” lift. You can also get drop shackles that allow you to lower the back a little too. You can get your alignment very close with the right shop.
Old Dec 16, 2017 | 06:38 PM
Whitey Ford
No problems pulling.
Old Dec 17, 2017 | 10:05 AM
MiamiPSD's Avatar
MiamiPSD
Yes it can be aligned by a shop that knows what they are doing. You can go the moog adjustable pills or you can go with a corrected stock pill. Either way, it’s a little time consuming but still you need someone that knows what they are doing. I have the 2 1/2 puck under the springs on a 2wd......and yes the alignment was off when I installed them....good luck finding that shop. If I remember correctly, I also had to grind a little of the arm so it wouldn’t rub....
Old Dec 18, 2017 | 08:59 PM
timmyboy76's Avatar
timmyboy76
Miami and Karlow... What shocks you guys go with? Just picked me up another truck but want to raise this one
Old Dec 18, 2017 | 09:31 PM
guitarpicr's Avatar
guitarpicr
Had the spacers put on mine several years ago. The guy that did it had to work at it a little but got them within specs. Rides good & tires wear good & even.
Old Dec 18, 2017 | 10:06 PM
MiamiPSD's Avatar
MiamiPSD
TB76... I’ll try and get you some pictures and information on the spacers I used and the moog adjustable sleeves that I put in to get it aligned.
Old Dec 18, 2017 | 10:16 PM
MiamiPSD's Avatar
MiamiPSD
These are the moog camber/caster sleeves I used....
Old Dec 18, 2017 | 11:38 PM
timmyboy76's Avatar
timmyboy76
Right on, Miami 👍....i should proofread my crap. Was also asking, what shocks both you and Karlow went with
Old Dec 19, 2017 | 06:47 AM
MiamiPSD's Avatar
MiamiPSD
Bilstein 4600....
Old Dec 28, 2017 | 05:17 PM
timmyboy76's Avatar
timmyboy76
MOOG K8979
So, I ordered the parts above..caster/camber bushings along with spacers. Bushing received today, but in a box from RockAuto. That company dropshipped from here. So, went to RockAuto site and the damn things are 7.40ea!!!!!
Pat-F250
Jan 21, 2019 09:41 PM
crisman
May 3, 2018 02:41 PM
7.3superdutty
Jul 9, 2017 10:08 PM
beastieboy
Nov 8, 2013 10:47 PM
hyperpunkguy[F150]
17
Oct 20, 2003 01:38 PM
