duel fuel tank problem
Old Dec 13, 2017 | 04:24 PM
lemonslg's Avatar
lemonslg
When I have fuel in rear and front tank and I switch to use the front tank the fuel in the rear ends up in the front. This is a 1996 f150 Eddie Bauer 5 speed standard cab. Where do I look first for the problem?
Old Dec 13, 2017 | 06:07 PM
rla2005's Avatar
rla2005
Welcome to FTE!
Fuel transfer is a very common problem on these trucks. We see this issue posted at least 2-3 times a week recently. The tank that is getting filled, in your scenario the front, has a bad valve in the Fuel Delivery Module. The fix is to replace the entire front FDM.
Old Dec 14, 2017 | 12:56 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
What rla said. Ford issued a recall for this problem. I would replace both pumps with updated versions, the other one WILL fail eventually.
rj1983
Mar 8, 2017 11:25 PM
frankmako
13
Mar 4, 2014 06:33 PM
jerrywc
Jun 23, 2012 01:23 PM
Ford4x4-JD70AB
Mar 8, 2009 01:20 AM
2cylguy
Oct 27, 2008 06:16 PM
