fuel tank issue
Old Mar 7, 2017 | 01:55 PM
rj1983's Avatar
rj1983
fuel tank issue
Ok, so I am having kind of a strange issue with me '89 f150. While driving on saturday I was using the front fuel tank and it ran out of fuel, no problem I switched to the rear tank and went to the fuel station where I filled the rear tank completely. I hadnt done a lot of driving at all however yesterday the truck started carrying on like it was out of fuel, so I switch to the front tank and keep driving no worries.
When I got home I got under the truck and listened to make sure that after recent work the fuel pumps were connected up correctly according to the markings on the switch, they were. Further investigation lead me to find that the rear tank was now empty but the previously empty front tank now had all the fuel in it.
My question is, has anyone else experienced this? and why would the fuel be pumping over to the front tank from the rear.
Any assistance would be much appreciated.
Old Mar 7, 2017 | 02:44 PM
Freightrain's Avatar
Freightrain
Tank selector valve is messed up. Common on these trucks. If one of the check valves gets hung up, it will return fuel to the wrong tank.
It's under the cab, on the inside of frame. Can't miss it, it has all the lines going to it.
Old Mar 7, 2017 | 11:32 PM
rj1983's Avatar
rj1983
Ok, thanks, I did suspect that one. either that or I thought the return lines could have previously been connected around the wrong way. Ill source a new one and replace it.
Thanks for the help.
Old Mar 8, 2017 | 01:59 AM
rj1983's Avatar
rj1983
Just has a look and the only selector valves that rockauto list are electrically operated and quite different to what is fitted to my truck. Has anyone had to source one of these valves that could point me in the right direction?
Old Mar 8, 2017 | 07:47 AM
Freightrain
I "think" the newer(92-up) version is different then the 87-91? There have been posts of this issue before, but can't say what the situation is.
Old Mar 8, 2017 | 08:21 AM
vjsimone's Avatar
vjsimone
What engine do you have?
In Dash Tachometer?
Old Mar 8, 2017 | 09:16 AM
Conanski's Avatar
Conanski
The switch valve is officially called the "dual function resovoir".
Old Mar 8, 2017 | 01:56 PM
rj1983's Avatar
rj1983
In Dash Tachometer?
Ive got the 5.0 litre V8 with an in dash tach.
Old Mar 8, 2017 | 02:38 PM
rla2005's Avatar
rla2005
You need to verify each low pressure in tank pump is functioning. A non-working in-tank pump will prevent the Dual Function Reservoir from switching between tanks.
No sense replacing the expensive reservoir when it's a fuel pump problem.
Some good info from Steve83: Fuel Reservoir Information
Old Mar 8, 2017 | 11:25 PM
rj1983's Avatar
rj1983
yes, pumps are definately working, they are brand new plus i can hear each one running when i switch between the two tanks.
Jarrett Campbell
Oct 11, 2015 10:46 AM
4Keith
May 27, 2011 12:16 PM
grizz 454
Feb 9, 2011 07:32 PM
poocher pup
Jul 19, 2010 09:27 PM
Ford4x4-JD70AB
Mar 8, 2009 01:20 AM
