Oil Leak
Old Dec 13, 2017 | 11:44 AM
bob60's Avatar
bob60
Oil Leak
On the timing chain cover behind the belt tensioner is this round metal plug about 3 inches in diameter and it has a stream of oil coming from it. I went to the local Ford dealer and they have no idea what it is or how to fix it. Anyone know what it is, or a part number, or a good way to seal it?
Old Dec 13, 2017 | 12:13 PM
YoGeorge's Avatar
YoGeorge
First, you might do well to say what engine it is (or put this info in a footer for the posts you make), and then make this post in the sub-forum devoted to that engine family.
The leak is not specific to a van and although we have a lot of mechanical people here, you're gonna get more views in a forum devoted to engines.
Best of luck with an answer. Sounds like you need a new dealer,
George
Old Dec 13, 2017 | 03:49 PM
annaleigh's Avatar
annaleigh
on first glance that looks like the belt tensinor has been rubbing against the timing cover. can you take a pic of how the belt tensioner mounts in that location?
If so then it would require a new timing cover and belt tensioner
Old Dec 13, 2017 | 07:48 PM
bob60's Avatar
bob60
The more I look at it the more I believe you are correct annaleigh.
Old Dec 14, 2017 | 08:41 AM
YoGeorge's Avatar
YoGeorge
Wow...that looks like the idler pulley worked as a hole saw. If this was your van, didn't you hear any noise? that had to take a while....
Old Dec 15, 2017 | 03:56 PM
vettex2's Avatar
vettex2
I'd hit it with some JB Weld and replace the aforementioned parts
Old Dec 15, 2017 | 04:20 PM
jeffreyclay's Avatar
jeffreyclay
Annaleigh, you are one sharp cookie!
Old Dec 16, 2017 | 09:45 AM
bob60's Avatar
bob60
the JB weld seems to have done the trick. I did replace the tensioner as an assembly and spaced it out by using one washer behind each of the 3 bolts. Thanks for all the help
Old Dec 16, 2017 | 11:42 AM
wirelessengineer's Avatar
wirelessengineer
George
What he said. Especially that last part!
DesertStorm
4 Cylinder Engines
Nov 24, 2007 08:51 PM
Tex311
1983 - 2012 Ranger & B-Series
Aug 5, 2007 04:46 PM
tonyford
Nov 28, 2003 11:33 PM
Critterhunter
Sep 10, 2002 09:21 AM
1998XLT
Jul 1, 2002 06:18 PM
