Newbie
Old Dec 12, 2017 | 06:33 PM
John11.25's Avatar
John11.25
Newbie
I just purchased a 1996 F250 HD 4x4 super cab, 7.3 PSD, w/204,000 miles. I also just discovered this forum and it is great. I have been the owner of a 2003 F150 gas engine(great truck) but this is my first diesel.
I have been reading several threads about fuel leaks because mine has one, on top and dripping down the back of the motor. When time permits I will try to see exactly where it’s leaking. It also has a oil leak at the oil filter.
Otherwise it seems like a good truck.
I would take any advice on general maintenance i.e coolant type, engine oil, and areas that need special attention.
Thanks,
Glenn
Old Dec 12, 2017 | 06:41 PM
oldbird1965's Avatar
oldbird1965
Use Fleet Charge concentrated coolant, Rotella or Schaeffer's like I do and the stickies at the top of the page is full of information. From one Glenn to another, welcome!
Old Dec 12, 2017 | 07:24 PM
97-psd's Avatar
97-psd
Stickies are a great source of information. Welcome! Any plans for the truck? We will gladly help you spend your money!
Old Dec 12, 2017 | 07:40 PM
oldbird1965
Don't scare him away Ben, lol.
Old Dec 12, 2017 | 07:42 PM
z31freakify's Avatar
z31freakify
Welcome aboard Glenn
Old Dec 12, 2017 | 08:19 PM
John11.25's Avatar
John11.25
I appreciate it. I had planned on keeping it stock, I’m not a very skilled mechanic. I can do general maintenance and minor repairs,... modifications not so much. I will use it to tow a John Deere tractor around and firewood hauling.
I have already learned quite a bit just by reading through various threads. A wealth of knowledge here.
I’ll have some specifics when I get into the fuel leak issue, no doubt.
Glenn.
Old Dec 14, 2017 | 08:44 AM
knottyrope's Avatar
knottyrope
mine leaked up there and was from pump to fuel bowl hose but I replaced the pump and rebuilt the fuel bowl for piece of mind. Bought all parts from riffraff.
some info I have collected on here
https://www.ford-trucks.com/forums/1...sel-truck.html
Old Dec 14, 2017 | 02:11 PM
John11.25's Avatar
John11.25
Thanks for the information, I had something weird happen today, started it up to check for fuel leak and after turning the switch off, the starter engaged, turning the motor but would not stop turning it over even with the key off and passenger side battery cable removed. Ever seen that happen? Not sure where to begin.
Old Dec 14, 2017 | 02:49 PM
knottyrope's Avatar
knottyrope
have to remove neg terminal from both of the batteries as they are wired in parallel
sounds like a bad starter or starter relay
Old Dec 14, 2017 | 03:12 PM
John11.25's Avatar
John11.25
I saw some older posts that indicated batteries need replacing, as low voltage could cause it. Is the starter relay on the passenger wheel well? It looks like it has been replaced before.
Old Dec 17, 2017 | 08:55 AM
John11.25's Avatar
John11.25
I Talked to the previous owner who said he replaced the starter and relay recently. I charged the batteries and it started without any problems. It looks like I will be replacing the batteries.
Dualblues
6.7L Power Stroke Diesel
Sep 5, 2014 10:48 AM
bigpimpin
Dec 1, 2013 02:45 AM
madmacs
Jan 16, 2012 06:04 AM
02350
Sep 27, 2010 08:57 PM
StephenBlethen
Feb 1, 2006 08:12 PM
