Try 80W90 , check if you have LS clutches in both, if so you need to add a friction additive or you will roast the clutches. The capacity is however much you need to fill the case up to the drain plug, usually 2-3 quarts per axle.
Sterling 10.25" will take more than an 8.8", I'd have 4qt on hand. 80w-90 for light duty but I always run 85w-140 conventional or 75w-140 synthetic. I'll take a little mpg hit over worn parts if hauling or towing.
http://www.dieselhub.com/maintenance/sterling-axle-fluid.html
Um, you fill it up to the FILL plug. There is no drain plug, and if there were, it would be at the bottom.....
The synth 85w-140 should cover you for open or limited-slip. If you're not sure which diff you have, check the AXLE code on the door jamb. If it's a letter and a number, it's limited slip; if it's two numbers, it's open diff.
AFAIK, the factory never shipped a LS front axle in this generation of truck.
