2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Whine coming from front end in 4H when accelerating?
Old 12-10-2017 | 08:16 PM
MrFord619's Avatar
MrFord619
Hey everyone, so yesterday was the first time I used the 4H in my truck. Roads were slushy and I just wanted to test the 4x4 system. Well I noticed a whine coming from the front end when accelerating, however it would go away when I let off the gas. The faster I went, the more pronounced the sound became. I could even hear it over the radio. I've owned many 4x4 trucks and I never experienced this before so I assume it's not normal. I'm going to the dealer soon to have some interior bits fixed, but I just wanted to know if anyone else as experienced this. Kind of sucks as the truck only has 5500 miles on it.
Old 12-10-2017 | 08:41 PM
mhoefer's Avatar
mhoefer
No harm in having your dealer check it out. Check your drive shaft bolts securing the u-joints front and rear as there have been a few reports of lose ones. Probably normal drive noise from the transfer case, and the front u--joints in the steering axle.
Old 12-11-2017 | 05:20 AM
MrFord619's Avatar
MrFord619
Wow loose u-joints from the factory? That's a big one to miss at the factory. Thanks for the heads up I'll check tonight. The noise is pretty loud extremely annoying and 'it's normal' better not be the answer I get from the dealer. Sadly, my 1986 F-150 has a quieter 4x4 system.
Old 12-11-2017 | 05:39 AM
Devildog95's Avatar
Devildog95
same issue
Old 12-11-2017 | 06:41 AM
RainDesert's Avatar
RainDesert
Same for mine. I believe it is the transfer case. Here are few other similar threads:
https://www.ford-trucks.com/forums/1...ing-noise.html
For the record and comparison, I have a manual transfer case. I don't have time to drop my truck off at the dealer to look into this issue. I would love any updates if anyone tries to get this issue addressed.
Old 12-11-2017 | 06:42 AM
RainDesert's Avatar
RainDesert
And this one from just the other day:
https://www.ford-trucks.com/forums/1...4wd-noise.html
Old 12-11-2017 | 07:02 AM
Buliwyf's Avatar
Buliwyf
Are the universals on the drive shaft greaseable? My 2015's shaft is getting noisy. I'll have to check it out.
Is there a greasable slip yoke? I haven't spent any time under my 2017 yet.
Old 12-11-2017 | 07:06 AM
RainDesert's Avatar
RainDesert
I will check today. I have had roughly a dozen SD's and never had this noise/humming before. I have been told it is not abnormal by some members.
Old 12-11-2017 | 07:53 AM
troverman's Avatar
troverman
The transfer case is a totally different design for 2017. Previously, it had been the NVG 271/273 for many years on the Super Duty.
It would be normal to hear just a small amount of front drivetrain noise when rolling or under acceleration. Frankly, I don't hear anything on mine.
I see MrFord and RainDesert are driving 6.2L trucks. Could it be that the 6.2L is so quiet that you hear the noise whereas the diesel exhaust tone masks it?
Anyone with a diesel have the problem? I've had two 2017 trucks and have not heard this whine, but both are diesel.
Old 12-11-2017 | 09:14 AM
fleming23's Avatar
fleming23
I ran mine for the first time in the snow this past weekend and really didn't notice any noise at all. I think my 2016 F150 may have made more noise when in 4H than the F250. My truck is 100% stock, FYI.
Old 12-11-2017 | 10:03 AM
HRTKD's Avatar
HRTKD
Boondocker
As far as I have found, the only grease fittings are on the u-joints on the axle next to the front wheels.
Old 12-11-2017 | 10:25 AM
troverman's Avatar
troverman
That would be correct.
vib8r
2017+ Super Duty
54
11-18-2018 08:42 PM
CFDer01
2015 - 2020 F150
12-07-2017 09:27 AM
bamawood
2017+ Super Duty
13
09-19-2017 07:11 PM
bang4dabuck
01-30-2008 07:48 AM
Wilber15
03-18-2002 05:22 PM
Quick Reply: Whine coming from front end in 4H when accelerating?
