DEAD 460
Old Dec 10, 2017 | 10:36 AM
alans77crew's Avatar
alans77crew
DEAD 460
I recently purchased 78 supercab mostly for the engine,it ran but a little ruff.So I took it home did all the usual stuff then ran a compression test 138 on all but #8 dead hole! yippie.So wasn't really concerned cause I'm putting dove heads on it. So last night I pulled the offending head and low and behold no burnt valve no hole in the piston no flat cam NOTHING WTF!!!!!!! Haven't checked the rings yet or for a sticky valve,but no scarring in the cylinder .Oh by the way it has an engine builder tag on the front so been rebuilt at some point. It is a D1VE block and D3 heads. Well any Ideas would be helpful at this point. Thanks in advance for any ideas
Old Dec 10, 2017 | 11:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by alans77crew
I recently purchased 78 supercab mostly for the engine, it ran but a little ruff. So I took it home did all the usual stuff then ran a compression test 138 on all but #8 dead hole! yippie. So wasn't really concerned cause I'm putting dove heads on it. So last night I pulled the offending head and low and behold no burnt valve, no hole in the piston, no flat cam...NOTHING WTF!!!!!!! Haven't checked the rings yet or for a sticky valve,but no scarring in the cylinder .Oh by the way it has an engine builder tag on the front so been rebuilt at some point.
Block casting number: D1VE-6015-AB or A1B or A2B = internal balance.
1971/73 429 Ford/Merc Passenger Cars / 1971/78 460 FoMoCo Passenger Cars & 1973/78 F100/350 / 1975/78 460 E250/350 / Some 1979 460 F150/350 & E250/350.
Old Dec 10, 2017 | 11:22 AM
alans77crew
it is internal balanced
Old Dec 10, 2017 | 12:48 PM
meangreen92's Avatar
meangreen92
How did the head gasket look? You can turn the head upside down, and see if the chambers, especially that #8, hold water in them, without leaking past the valves - although I don't know that you want to use water, if you have something else around like rubbing alcohol or something.
Old Dec 10, 2017 | 01:00 PM
alans77crew
head gasket were fine good sealing all around,I was going to check the valves this afternoon
Old Dec 10, 2017 | 11:40 PM
1976 f-250's Avatar
1976 f-250
Alans77, for checking static sealing of valves to seats I simply use parts solvent and do the testing in my solvent washer. I also use a strong LED flashlight and watch the leaks, if any, through the respective ports. You may have some wicking/wet area under the valve seat but you may also have a trickle or free flowing-this is what I mainly concern myself with. Then I chuck up the cleaned up valve in the valve grinder and see if it is bent. You can do the same in a drill chuck for example. I have seen engines that had severe detonation break piston rings but they still had some compression showing on the gauge.
Old Dec 11, 2017 | 03:12 PM
79F150400M's Avatar
79F150400M
I had the same thing happen to me a few years ago on a 460 i was working on. Had good compression on all cylinders except numero 5....it had zero. Found out there was a short pushrod. Bought 2 new ones that were the same length as the other pushrods and it solved the problem. Hope this helps...
Old Dec 11, 2017 | 03:40 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Possible cam lobe bad?
Old Dec 12, 2017 | 07:45 PM
alans77crew
Well got busy but did find the problem.could not see it for looking at it, did what you guys said filled the combustion chamber and it leaked broken valve spring in three pieces! dont know I didnt see but damn sure didnt! thanks everyone al
Old Dec 13, 2017 | 11:47 AM
somethingclever's Avatar
somethingclever
Glad to hear. That is a good test....I like to use kerosene.
Old Dec 13, 2017 | 12:03 PM
1976 f-250's Avatar
1976 f-250
Unless you are on a tight budget, I would think it prudent to replace all valve springs in case any more are getting ready to shake hands with you. You got lucky this go round since you didn't have a dropped valve in the cylinder from the broken spring, tearing up components. That will take a bite out of yer wallet.
Old Dec 16, 2017 | 08:34 AM
alans77crew
Its getting dove heads and a new cam kit. yep been down that road before my personal truck had a 400 in it and it broke 4 valve springs in as many months, that's why she has a cummins in it now.this truck is one we are building for my youngest boy. it seems like since I put the cummins in both my boys have been bitten by the dent side's so they both have project sc's 4x4's in the wings, in the past 2 years we have parted 5 roached supercabs for parts for them, should be fun when we have them done!!! Thanks again guys as I said couldn't see it for looking at it!
OutlawCountry89
May 6, 2017 04:54 PM
ford69gt
Jun 13, 2016 03:10 PM
BigBlocker0248
Jun 29, 2015 11:41 AM
mebe2k
Feb 13, 2015 02:29 PM
fordtruggy
Jun 4, 2006 11:35 PM
