Door Handle Installation
Old Dec 9, 2017 | 10:43 PM
Gigemags05's Avatar
Gigemags05
My 47 half ton does not have any exterior door handles on it, I removed them 4 years ago when I got the truck and I did not do my due diligence and pay attention to the process when I removed them. I have purchased new handles form MACs but I can't figure out how to install them.
I also have new interior handles and can't figure out how to remove the old ones to put the new ones on.
Lastly, I have a new lock cylinder for the passenger door. How does that work? It seems like I may be missing a piece or something. There is just the hole for the cylinder, it doesn't appear as if there is anything for the shaft to grab. Is there a piece that goes through the hole on the side of the door that is supposed to catch the shaft of the cylinder?
Any insight or advice is greatly appreciated. It looks as if the shafts on the new handles may need to be cut, as they are really long. Is that common?
Old Dec 9, 2017 | 10:54 PM
tacomacream's Avatar
tacomacream
There is a lot of info on this here:
https://www.ford-trucks.com/forums/s...rchid=25855623
Old Dec 10, 2017 | 07:16 AM
Gigemags05's Avatar
Gigemags05
I clicked on the link but it says there is no content.
Old Dec 10, 2017 | 08:28 AM
tacomacream
^^ i fixed it
Old Dec 10, 2017 | 10:34 AM
Gigemags05's Avatar
Gigemags05
Thanks. I got the link to work on my phone but still won't work on the computer.
Through that link I think I figured out the lock cylinder. One of those threads says that the set screw is a 6-32, which I thought was odd. Sure enough, that's not the case with mine. I am not sure what size it is, but its much larger than 6-32.
Is it normal to have to trim the shaft on a new replacement door handle/lock cylinder?
I cannot seem to find anything on the exterior or interior door handle install. I used the search function to no avail.
Old Dec 10, 2017 | 10:55 AM
tacomacream
It worked when I first posted it but now this one doesn't work either. I know that you have found it now but for others try this:
Old Dec 10, 2017 | 04:37 PM
newold46's Avatar
newold46
I had to trim my door handles. Then again, they were from a '34 car. They came with door locks, so I didn't have to mess with the one.
Old Feb 11, 2018 | 05:45 PM
Gigemags05's Avatar
Gigemags05
I figured out the exterior handle, but am still having trouble getting the interior handles off to replace them.
Also, I ran into an issue. The passenger side door handle will turn but does not engage the door hardware inside the panel. It looks like the square hole that the handle fits into has rounded itself off and the handle is turning freely.
Old Feb 22, 2018 | 06:58 PM
Gigemags05's Avatar
Gigemags05
I pulled the latch assembly and cleaned it up really good. While it was out, the handle mechanism was working just fine. I trimmed the corners of the handle about an inch up from the end and now it works well when on the door.
My next issue: i‘m missing three of the screws that hold the latch assembly in place on the doors. I took one to the hardware store but couldn’t match the size. Does anyone know what size screws those are?
zippi
1947 and Older Ford Trucks
May 21, 2017 08:55 AM
thomc
Mar 27, 2017 08:35 AM
Marauder2004
16
Mar 30, 2014 08:46 AM
Matt Scassero
Sep 14, 2004 09:58 PM
