Sponsored by: Real Truck
Enable Remote Keyless Entry
Old Dec 7, 2017 | 06:04 PM
Lead Head's Avatar
Lead Head
Hey guys,
A friend of mine has an '04 6.0L F-350 that he thought had RKE, so he bought new fobs, then found out his truck didn't come with RKE. He knows I have a computer with FORScan and heard that I could enable RKE with it.
I just want to make sure that I actually can just do that, and he doesn't need any additional hardware to make it happen?
Old Dec 7, 2017 | 07:21 PM
Just Strokin's Avatar
Just Strokin
Does his vehicle have power door locks? If not, then no way it can be made to be RKE. The truck would need the RKE module and you would need to know where to make the change with FORScan if you are able to do it.
Old Dec 7, 2017 | 07:36 PM
Lead Head's Avatar
Lead Head
It has power locks
Old Dec 7, 2017 | 07:58 PM
Just Strokin
Do you know what to "turn on" with FORScan? You might need to post this question over in the forum that covers the 2004 model SD trucks instead of here.
Old Dec 7, 2017 | 09:24 PM
Lead Head's Avatar
Lead Head
That's what I was hoping someone would be able to help with.
Old Dec 7, 2017 | 10:38 PM
bobv60's Avatar
bobv60
The power lock system is different between the trucks with RKE and Without RKE. I am pretty sure there is hardware missing and there is basicly nothing to turn on.
I had a 2003 that had power locks but no RKE. I had to buy an aftermarket RKE and add it to the truck. It was actually less expencive than a set of OEM fobs, about $50 for everything.
Old Dec 8, 2017 | 12:14 AM
Mike189677's Avatar
Mike189677
If it doesn’t have keyless entry from the factory it doesn’t have the module and you can’t turn it on with any computer. The turning on options with forscan doesn’t work with the older trucks like the newer ones. If he wants keyless entry get an aftermarket system and get remote start while he’s at it and be done with it.
Seahn
Feb 7, 2025 03:05 PM
mitch289
Oct 19, 2008 03:20 PM
nasdaqsam
Nov 29, 2005 03:50 PM
fiveinarow
Nov 18, 2003 01:39 PM
gillweb
1997 - 2003 F150
Jul 24, 2003 12:02 PM
