C6 Crossmember?
C6 Crossmember?
Hey all,
I have a 79 Ranger 302 which had the original C4 trans removed at some point and a C6 was put in it's place.
NOW they cut the original crossmember and I cannot for the life of me find if there was ever a 79 f100 ranger equipped with a C6 and if it was i cannot find the part number to track one down. I checked here and didn't see it but I may have missed it : https://www.fordification.net/partno...rossmember.htm
What are my options
Fabricate?
Aftermarket like the one used for crown vic setups?
Here is the only pic i have of it atm as it's in the shop (circled in red)
What are my options
Fabricate?
As I read it a C4 was in a 6cly and 302 trucks and a C6 in all others V8's. But I have read things wrong before.
https://www.fordification.net/tech/t...3-79trucks.htm
So here is how a member modified his trans cross member so he could unbolt the middle section, to make removing the transmission easier. Maybe you can use this as a way to connect the 2 ends on your truck.
https://gearstar.com/ford-c4-and-c6-...bell%20housing.
parkerusmc
11-05-2005 11:56 AM
duece-bigalo01
04-25-2004 01:38 AM
