78 turn signal problems
Old Dec 3, 2017 | 05:03 PM
Mac92's Avatar
Mac92
I just put a new turn signal switch in. I have left turn signals but no right. The rear right will light up but not flash. The right front doesn't even illuminate. Put new bulb still nothing. Please help
Old Dec 3, 2017 | 11:41 PM
meangreen92's Avatar
meangreen92
Make sure that the front socket is good. Verify voltage there. And make sure that there's a ground wire to the body/frame/rad support, coming from the lighting harness at all four corners. Are the indicators in your dash cluster working?
Old Dec 4, 2017 | 12:36 AM
75BigBlock's Avatar
75BigBlock
x2 on what meangreen said.
Check the contacts within the sockets. None of my Bronco's side markers would light up when I got it. I cleaned the left front and it came on. I cleaned the left rear and it came on. After I cleaned those two suddenly the right side started working. Be thorough!
Old Dec 4, 2017 | 08:20 AM
HoustonDave's Avatar
HoustonDave
Be sure to check ground continuity THROUGH the sockets. Once I had great grounds at the sheet metal, juice to all the appropriate spots...and flaky lights - till I determined I had defective ground wire connections in the sockets. The front socket was easy to replace via Dorman, the rear I had to cut open along the side and resolder the ground wire to its tab. No issues now.
Old Dec 5, 2017 | 11:59 PM
Mac92's Avatar
Mac92
Thanks guys for the help it was a bad socket
accent2010
Escape & Escape Hybrid
Feb 25, 2018 11:36 PM
corkel
Electrical Systems/Wiring
Jan 10, 2014 02:58 PM
basecamp
Jul 5, 2007 12:44 PM
the tank
Feb 28, 2005 12:16 PM
paflyfish
1983 - 2012 Ranger & B-Series
Jul 26, 2004 11:42 AM
