Battery light
Old Dec 2, 2017 | 03:26 PM
anton5052's Avatar
anton5052
Battery light
My Battery light has started coming on intermittently. Seems to be more prevalent at higher RPMs which is strange.
Im going to start by replacing the Alternator. Any recommendations on good aftermarket ones ? I have read that the basic re manufactured ones from the auto part stores dont last long in these trucks.
Thanks in advance!
2005 Ford Excursion 6.0 L Diesel.
Old Dec 2, 2017 | 06:09 PM
jspence105's Avatar
jspence105
Before replacing it test the wiring harness that goes to it. I fought with an "alternator" issue for a long time before I found the harness was bad on my 7.3.
Old Dec 2, 2017 | 07:21 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yep, what John said. Go through all the wiring and ohm it all out. Test for voltage drops between the alternator and batteries. The little plug on the back of the alternator fails over time due to the heat cycles.
Old Dec 3, 2017 | 01:48 AM
kawika904's Avatar
kawika904
Yes, definitely get the cause of the issue corrected first. If you want/ or have to replace the alternator, I and many others have gone with the high outputs from DCPower https://www.dcpowerinc.com
They are great units that hold up well. Their website may show as sold out. Give them a call anyway or call the guys at FICM repair.com. They stock them
Good luck, let us know when you find the problem and if you replace the alternator
Old Dec 5, 2017 | 11:58 AM
anton5052's Avatar
anton5052
I ohmed out the large red wire to the battery and it was fine. Im not sure how to ohm out the other wires on the plug.
Old Dec 5, 2017 | 02:24 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
what number did you come up with when you checked resistance on the B+ wire? What is the voltage drop across it?
Old Dec 5, 2017 | 03:50 PM
csnow's Avatar
csnow
I would also stop driving it. I had a fire due to the alternator bearing going out. It started with the random battery light indicator that my wife failed to mention.
Old Dec 6, 2017 | 06:12 AM
projectSHO89's Avatar
projectSHO89
Classic symptom that happens when the alternator brushes are almost worn out. They start to float above the commutator contacts at higher RPMs and the alternator output drops turning on the light.
Time for a replacement alternator.
Old Dec 7, 2017 | 10:45 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I had one that would trigger the light around 5,000 rpm. Took the truck on a road trip with many high speed passes, finally on the way home after 1,200 miles I was making a pass at 5K and the light did not go off after slowing down. Made it the last 50 miles home with everything electrical turned off that I could running on the battery..lucky!
Old Dec 15, 2017 | 08:18 AM
anton5052's Avatar
anton5052
Ok, to update you guys, ? I went to FCIMrepair, and ordered a 185 amp alternator. I installed it per directions (charging batteries prior to starting).
Now, the battery light is gone, however, im seeing another issue. The instructions say the alternator should be charging over 13.5 volts. Im seeing 11.8 at idle.
Any ideas here ? Do you guys think the Alternator may be bad ? The batteries are only a year old.
Old Dec 15, 2017 | 08:27 AM
Twitchyleprechaun's Avatar
Twitchyleprechaun
I also fought with battery and charging issues for a while before figuring it all out. My main issue was the pigtail going to the alternator. I finally figured it out because when the battery light came on I got under the hood with the truck running and jiggled the connection. While messing with it, you would hear hear changes in the idle from the extra load of the alternator kicking on and off. I went through 5 alternators, and a set of batteries before figuring that out. Once the pigtail was replaced, I switch the alternator and batteries one last time and have not had an issue in almost 2.5 years.
Old Dec 15, 2017 | 09:05 AM
anton5052's Avatar
anton5052
Did you replace the entire pig tail ? or just the plug itself ? Im not sure where the other end goes.
The new alternator came with a new pigtail, however it plugs into the existing one, then to the alternator.
Old Dec 15, 2017 | 12:11 PM
anton5052's Avatar
anton5052
You nailed it Twitchy, it was the damn pig tail, I cut it off, and spliced in a new one, now I have 14.5 volts charging at idle!
Thanks man!!
Old Dec 15, 2017 | 06:09 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Reps given for closure and to Twitch, but go back and read posts #2 and 3.
Diverdan0430
Jun 19, 2017 02:30 PM
fancyvern
Nov 2, 2012 03:34 PM
Garden Spyder
Kansas Chapter
19
Sep 27, 2009 09:19 AM
Neil64
21
May 8, 2009 07:05 PM
gofast51004
Feb 21, 2009 03:51 AM
