Dual tire equalization
Old Dec 2, 2017 | 12:21 PM
wrvond's Avatar
wrvond
I am wanting to install something similar to the Crossfire dual tire equalizers on my truck, but it seems to be kind of on the large size.
Has anybody done this sort of thing to their truck? What did you use?
Thoughts, ideas and experience most welcome!
Old Dec 2, 2017 | 12:50 PM
KCJackson1's Avatar
KCJackson1
21-1/2 years of having a dually as my daily driver - never saw the need for an equalizer. I just use a traditional dual-wheel gauge and check them both as needed.
Old Dec 2, 2017 | 12:59 PM
wb6anp's Avatar
wb6anp
I used something like this on my motorhome, https://www.zoro.com/westward-dual-t...xoCkR4QAvD_BwE
Old Dec 3, 2017 | 07:14 AM
porthole's Avatar
porthole
When I fill the tires I use a home made equalizer.
I have a PowerTank.com pressure gauge with 'push to connect' (PTC) 1/4" connectors.
3 pieces of 1/4" hose, two right angle push on tire fill valves and a 1/4" Tee.
Use it for the truck and dual axle trailer tires when adjusting pressures.
Old Dec 3, 2017 | 09:13 PM
First Dually's Avatar
First Dually
Originally Posted by porthole
Is this the exact model you gauge you use? Link says it is 40 PSI max.
Old Dec 3, 2017 | 10:20 PM
porthole's Avatar
porthole
No, I just picked a generic gauge when I looked at the website.
This is the kit I bought (150 psi) but I had them change the whip to 24" which reduced the cost some.
Power Tank - Tire Inflators / Tire Gauges Digital Tire Inflator 150 PSI 6 Foot Braided Hose Clip On and 2 Dual Head Chucks Power Tank - Powertank.com
Old Dec 4, 2017 | 12:24 AM
memacon's Avatar
memacon
I drive a semi for a living . Had the crossfires on my tractor. after about 6 months they started to leak. Pulled them all off and just checked my tire pressures manually same as KCJackson1
Old Dec 4, 2017 | 06:58 AM
2009kr's Avatar
2009kr
I fill with a Milton 553.
https://www.amazon.com/gp/product/B00MXU5B3G/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
It allows a safer fill (though not as far away as the sticker on my F450 says to be). It is easy to lock on the stems and stand away to fill. The gauge is consistent as well.
Old Dec 4, 2017 | 07:50 AM
wrvond's Avatar
wrvond
They look like they could be a bit fussy, especially on smaller tires. The company claims a potential 20% tire life increase, which would be nice, but may not really be enough to cover the cost of the valves.
I'm more concerned about accelerated wear on the inside tires due to higher temperatures. Using the manual pressure gage is what I do now, but if the inside tires roll at a higher pressure due to higher temps, the only effective method to reduce or eliminate that difference that I can see is some kind of device similar to the Crossfires.
I'll keep looking, perhaps I will come across something purpose built for small truck tires rather than something adapted from tractor trailer tires.
Old Dec 4, 2017 | 09:31 AM
Baldicon's Avatar
Baldicon
I have a more novice question, how do you get the inside tire valve stem cap off? Mine are mounted with the inside valve stem in the same wheel opening as the outside valve stem, and I can't get my hand through to take the inside cap off!
Old Dec 4, 2017 | 02:07 PM
wrvond's Avatar
wrvond
It should come with a cap that you can fill through. If you reach through with your finger and feel the tip, it should feel like a spring loaded ball, or similar. Just press the chuck down over it.
Old Dec 4, 2017 | 07:27 PM
Baldicon's Avatar
Baldicon
I'm wearing my embarrassed face and dunce hat. Like a novice, I was trying to get the caps off. Thanks.
Old Dec 4, 2017 | 08:14 PM
JHatley7's Avatar
JHatley7
I went a step further and rotated my outside wheels so i could get my hand in there. Then realized the flow through caps.
Old Dec 4, 2017 | 08:18 PM
Baldicon's Avatar
Baldicon
I was actually thinking of doing that when we get back home!
speedybill
Nov 10, 2014 07:56 PM
Supercab
Jul 31, 2007 10:39 AM
Greywolf
All Things Towing
May 1, 2007 10:36 PM
stryder
Feb 4, 2007 10:19 AM
bipacco
Jan 11, 2005 11:55 AM
