Tools and Gadgets Thread
Old 12-05-2017, 10:04 AM
ExPACamper's Avatar
ExPACamper
ExPACamper is offline
Originally Posted by bigb56
Here's the pics as promised. The base is 1/4" X 2" hitch tube welded into a wishbone, it slides into the front hitch which I drilled and tapped for a 3/8" bolt to take the slop out for stability. The sides are 1" X 3" 16 gauge tube, the steps are 1/2" X 1/2" 1/8" angle frames with expanded metal welded on top. The chest pad is made from two pieces of 1/8" X 1" X 2" angle that I rounded at both ends and drilled it out for the hinge pins that allow it to be adjustable and folding. I drilled two more sets of holes for removeable clevis pins to hold the chest pad at two different places when in use. The top is 3/4" plywood with a foam cover. All edges are rounded or capped and smoothed for safety. The wishbone folds up into the stair body, the chest pad folds down and it all hangs on the wall. It probably weighs 40-50 lbs, if I had to do it again I would consider aluminum. Or maybe lightening up the wishbone with 3/16",
oops almost forgot the two forward braces that keep the steps up are more 1" X 2" angle.
edit: just checked, the wishbone is 3/16"
If I could make a suggestion...
Drill a hitch pin hole in the end of that bottom piece of box steel (truck side) and fab a H shaped leg that extends under the truck.
Mine extends under the truck and I often lean way out past the platform and it is pretty solid
  #32
Old 12-05-2017, 10:34 AM
Quick444's Avatar
Quick444
Quick444 is offline
This one. It installed in seconds and works great
https://chrome.google.com/webstore/d...pkaon?hl=en-US
Thank you! I had already found two others and installed them to no avail.
This makes me mildly regret paying the big bucks to unlock my Photobucket account.
  #33
Old 12-05-2017, 05:31 PM
bigb56's Avatar
bigb56
bigb56 is offline
I'm not sure what you mean, unless you are thinking mine stands on the ground. It does not, it slides into my front hitch and is solid as a rock.
Although making long legs for it is a thought, to be able to use it on trucks with no front hitch.
  #34
Old 12-05-2017, 05:55 PM
ExPACamper's Avatar
ExPACamper
Yeah, I was thinking those were legs My (not home made) version is quite old and has legs on wheels, like a cherry picker.
  #35
Old 12-06-2017, 03:44 PM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is offline
My injector breakout box has successfully kept any injectors from failing for over ten years now. All you need to do is make a tool, and the truck won't want to fail that part anymore.
https://www.ford-trucks.com/forums/6...with-pics.html
  #36
Old 12-06-2017, 05:39 PM
ExPACamper's Avatar
ExPACamper
I need to build one of these someday! Very nice
  #37
Old 12-07-2017, 07:39 AM
Tugly's Avatar
Tugly
Tugly is offline
I recently did an oil change at night - I hadn't done this in the dark before. This is when I learned my under-hood light mod really worked. [
LINK LINK
  #38
Old 12-07-2017, 07:54 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Originally Posted by Tugly
I recently did an oil change at night - I hadn't done this in the dark before. This is when I learned my under-hood light mod really worked. [LINK]
That improvement is enticing, how are they mounted and how are they turned on and off?
  #39
Old 12-07-2017, 02:46 PM
Hussler's Avatar
Hussler
Hussler is offline
Measuring the MAP sensor output is almost impossible. That is because it is frequency based in HZ and not a DC voltage. Next time you purchase a digital volt ohm meter spend a few extra dollars and get one with a HZ option on the dial.
To measure the MAP output frequency find the MAP output wire to the PCM, usually the center connector on the plug. I don't like damaging wires any more than necessary so use a safety pin, borrowed from the wife, she probably won't want it back. Here is a picture of that pin stuck through the wire, some blood from my fingers were necessary to accomplish this task.
This was on my 97:
Next connect the positive lead on the meter to the safety pin and any ground to the negative lead. Set the meter to the HZ scale, turn the key ON but don't start. Here is a picture of the meter displaying the frequency at my altitude, guessing about 1700 feet above sea level.
If you are brave enough disconnect the MAP hose from intake and blow thru the hose, the HZ will go up a bit but not much. You can use a compressor as I did .. 0 to 20 PSI steps and the frequency went up proportional to the pressure indicating the MAP was functional. There are charts that show the conversion.
Will you use the every day, nope, but your buddies will really like the fact the MAP is working as designed.
  #40
Old 12-07-2017, 04:44 PM
Tugly's Avatar
Tugly
Tugly is offline
That was one of my easier mods. I recall a hole in the hood support there, and I just shoved a 1/4" bolt through (going off memory) to a nylock. The tilt switch never did me any favors, so I installed a sealed switch under the hood - and I use the lights only when I need them. You can see the switch on the driver side firewall.
I did the math, and two of these LED assemblies use half the power of the one stock bulb - but the light quantity is remarkable... it lights up the area in front of the truck. Each disc puts out 500+ lumens, where the old bulb put out 265 lumens. To make matters worse, those 265 lumens were divided by 360 degrees of projection (half of the light aiming at the hood), where the disc aims all the light away from the hood.
In essence, installing two of these is like installing 8 of the old bulbs - but these discs divvy up less than an amp of juice.
I wish I could take credit for first finding these, but that honor goes to Woodnthings. I can tell you the get the clear lens, but the hue is still just a tad blue. The blue hue doesn't really bother me... it's better than black.
  #41
Old 12-09-2017, 11:43 AM
Y2KW57's Avatar
Y2KW57
Y2KW57 is online now
Received 3,375 Likes on 1,768 Posts
You mean like this?
  #42
Old 12-09-2017, 12:19 PM
CGMKCM's Avatar
CGMKCM
CGMKCM is offline
I have been using this for the last year and I am happy with light output and battery life. It is also corded so even with a dead battery it is usable. Works well under hood and for interior detailing.
Amazon Amazon
  #43
Old 12-09-2017, 12:54 PM
ExPACamper's Avatar
ExPACamper
Originally Posted by Y2KW57
You mean like this?
Like this:
  #44
Old 01-17-2018, 03:02 PM
ExPACamper's Avatar
ExPACamper
Oring Maker Kit
I kid you not. Just saw this video of Loctite Oring Maker Kit.
Anyone use it or something like it?
  #45
Old 01-17-2018, 03:10 PM
Walleye Hunter
https://youtu.be/ZbOERBZrc9s
I have not seen that kit but I have seen O ring rope listed when I was snooping around at O rings, I forget where though.
Quick Reply: Tools and Gadgets Thread
