Keep knocking off oil filter
Old Dec 4, 2017 | 12:32 PM
jav_eee's Avatar
jav_eee
I asked this question a while back on the day my buddy punched a hole in his oil filter after running over a t-post that was hidden under some dirt. It left him stranded an hour from home out on the ranch. He had to wait a while for someone to get out of work and go buy oil and a filter to take to him. Someone recommended a skid plate that some company made. I’ll look back and see if I can find it.
Old Dec 4, 2017 | 12:37 PM
jav_eee's Avatar
jav_eee
Here it is.
~$600
The general consensus is usually “the chances of it happening are so rare that the cost to prevent it is too high.â€
So figure out how much being able to make it home is worth to you and do whatever the hell you want because it’s YOUR truck. ðŸ‘ðŸ½
Old Dec 18, 2017 | 09:03 PM
DeeDubz's Avatar
DeeDubz
This is the second time my motor craft filter has leaked. I haven't noticed any spots on my drive way but I think ill be trying something other than motor craft. I wiped it off and ill check it in a couple of days.
Old Dec 18, 2017 | 09:13 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
What I am seeing is possibly either overtightened or undertightened filter or the filter body on the truck is warped or has a metal burr tearing the gasket.
my_crib_too's Avatar
my_crib_too
Are you sure this comes from the filter and not some other part of the motor and just dripping off the filter? To my eye, and I could be very wrong, it seems like other areas in the picture look oily/dirty.
Bruce...
Old Dec 19, 2017 | 08:55 AM
DeeDubz's Avatar
DeeDubz
I check it out and see if its come from above the filter housing. The filter is on the tight side. That was the only way to get it to stop leaking.
Old Dec 19, 2017 | 10:21 AM
troverman's Avatar
troverman
The F-150 offers a "skid plate" on FX4 models that covers the bottom of the engine. The Super Duty FX4 "skid plates" cover the fuel tank and a very small one under the transfer case. The engine is fully exposed.
I'm mostly terrified of crunching the DPF off-road compared to anything else.
Old Dec 19, 2017 | 10:59 AM
Painted Horse's Avatar
Painted Horse
Did you make sure you got the OLD GASKET off? I find when I remove the old filter the old gasket likes to stay stuck to the mounting plate. When I put a new filter on, I now have two gaskets and it will leak like your photo.
Old Dec 19, 2017 | 12:19 PM
djousma's Avatar
djousma
Yea, I notice that a lot too, that the old gasket stays on the mounting plate. Its now part of my routine, as almost everytime it stays.
Old Dec 19, 2017 | 12:25 PM
DeeDubz's Avatar
DeeDubz
The old gasket was stuck when i took the filter off. I always check now.... Ive made messes before. When I went to wipe down the housing I found the old gasket in the rag.
Old Dec 20, 2017 | 09:27 AM
donovan's Avatar
donovan
600 bucks skid plates
For that price do they install them for you. If it is a real problem for you I would relocate the oil filter.
Take a look at where the fuel filter is.
Old Dec 20, 2017 | 10:15 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
build a skid plate, maybe utilize oil pan bolts, or fab something with gussets that attaches to the radius arm?
Old Dec 20, 2017 | 08:36 PM
  #28
bigredtruckmi
Veteran: Navy
Another thought. Be sure to lube the seal before install.
Old Dec 20, 2017 | 09:51 PM
  #29
DeeDubz's Avatar
DeeDubz
yep i pre lube
Old Dec 21, 2017 | 08:40 PM
  #30
bayou barataria's Avatar
bayou barataria
My truck does the same thing, I have to tighten the crap out of it, sometimes I worry about breaking it, or it will leak. I always lube the seal and make sure the old one is off. It has been like that since the truck was new.
