Tail Gate Won't Open
Old Dec 1, 2017 | 07:55 AM
Tommiezz's Avatar
Tommiezz
Unhappy Tail Gate Won't Open
I've had my new XLT 350F less than two weeks & last night was the 1st time to lower the tail gate but it won't open. When I double click my key fob to unlock I hear a clicking noise on the tail gate but it still will not open or unlatch. I've searched on Google but no good suggestions...I need help. I'm sure its something simple....Thanks
Old Dec 1, 2017 | 08:12 AM
rwtdct's Avatar
rwtdct
After you hear the click noise can you pull on the tailgate to open? If yes, mine had the same problem after a spray-in bed liner. I had to trim some of the bed liner off so it wouldn't catch. Also sometimes the rubber bumps near the latches will hold it up, you might have to do some shaving there.
Old Dec 1, 2017 | 08:25 AM
2009kr's Avatar
2009kr
Push on it when you hit the button. Mine did this once, but it loosened up after that.
Old Dec 1, 2017 | 08:26 AM
mjlaupp's Avatar
mjlaupp
I don't know if this will help. MY 2011 F250 with a manual latch would sometimes do the same thing. I found that pressing inward on the top of the tailgate while I pulled the handle would allow the latches to release and the tailgate to open.
Old Dec 1, 2017 | 08:43 AM
roadpilot's Avatar
roadpilot
Had the actuator that unlocks the tailgate go bad on my '15 F150 about a year after I got it. Using the fob, the button on the tailgate or the one in the cab produced no sound or effect. The dealership replaced it under warranty.
Old Dec 2, 2017 | 06:12 AM
camping nut's Avatar
camping nut
push the tailgate losed again then try to open it.
Old Dec 2, 2017 | 06:24 AM
finnf250's Avatar
finnf250
Had the exact same thing happen to my '17 F250. Turned out to be a faulty actuator, replaced under warranty
Warpburn
Aug 23, 2018 08:29 AM
02f350gurl
Dec 15, 2010 09:17 PM
berry1234
Apr 18, 2009 02:24 PM
That_Guy
19
Jan 4, 2009 05:32 PM
jba
2004 - 2008 F150
Oct 11, 2005 09:22 PM
