Sponsored by: Real Truck
Gear Swap
Old Nov 30, 2017 | 08:01 PM
Icecube508's Avatar
Icecube508
Gear Swap
I've been scouring the forums for the information I'm looking for but I just don't seem to find the correct information. My 015 SD is geared from the factory with 4:30's but I'm not even close to my max weight rating of the truck @35k. I scaled at 26500 fully loaded with my 5er and was thinking of going down to 3:73's since that is the where the carrier break is. Has anyone done this and noticed any difference in how the truck pulls or behaves? I know the cost is a bit on the high side since I have to do both f&r axles. Only reason I want to do now is I don't tow as much as originally intended and have a Max load of2k lbs of tools anyway. And when i do pull a smaller trailer it's only weight is around 5-k
thoughts anyone?
Old Nov 30, 2017 | 08:36 PM
Just Strokin's Avatar
Just Strokin
How much fuel can you buy for the cost of the gear change verses how long it will take at the current MPG to use the equivalent $$ in fuel. Convert the miles in to years to cover that many miles.
I doubt your fuel mileage will increase drastically doing a gear change. So, if you gain 15% better mileage, how long in months and miles will it take to offset the cost of the gear change?
Old Nov 30, 2017 | 08:48 PM
Icecube508's Avatar
Icecube508
Gear swap.
I roughly calculated my average fuel costs $4600/yr. So even if it was a rough15% savings it be $685/yr. The cost of the swap would be 2800 for both axles. So if the math is right it be 4 years to pay for it's self. Which is quite a bit of time.
Old Nov 30, 2017 | 09:16 PM
Sam I Am's Avatar
Sam I Am
Resale value is better with the 4.30 gears.
And you may not be satisfied with the performance of it with 3.73s.
It is extremely rare for anyone to want to go with taller gears, virtually everyone talks about going lower, id est higher gear ratio #.
Old Nov 30, 2017 | 09:39 PM
irydasteelhorse's Avatar
irydasteelhorse
I would love to have those 4:30s. my v10 truck with 3:73s and a 4500# 5th wheel isn't a dog, but some of those long steep pulls I sure wish I had more grunt. I get 9 mpg towing, and I bet id get 9 with the deeper gears too, but id be smiling all the way up the hill.
Old Nov 30, 2017 | 11:42 PM
brandon_oma#692's Avatar
brandon_oma#692
I swapped to 4.10 in my truck but I had 4.88 to begin with and it is 2wd. I wasn't also putting in a locker so the gear change was a second thought.
Old Dec 1, 2017 | 05:20 AM
Ron94150's Avatar
Ron94150
My guess is that even with just 2k in the truck, you will not gain any mileage dropping gear ratio’s. But if it is something that you think you truly want to do, it shouldn’t cost you a dime. There are countless people on this board that would love to swap you their 3.73s for your 4.30s. I think you would regret it though. What kind of mileage are you getting in what conditions?
Old Dec 1, 2017 | 06:57 AM
Diamnd1's Avatar
Diamnd1
I just went from 3.73 to 4.30. Towing my 9000k camper really made the truck work the skinny pedal and was getting ~7-8 mpg. After gear swap, different truck. I tow at 65-70 mph and mpg's improved to 9-10 towing and the truck does it soo much easier. I did not notice a drop in mpg's empty either. Though I do not drive it daily and I have no interstate commute.
As said it is your decision, but if you are asking for advice on what to do, DON'T! 4.30 gears are much more desirable in the gassers.
Old Dec 1, 2017 | 07:35 AM
Chuck's First Ford's Avatar
Chuck's First Ford
You MIGHT be the First to Want 3.73 and TOW anything..
find a fellow owner with 4x4 and 3.73 and exchange axles... no gear setup..
just R&R differentials.. and bleed brakes.
I bet you will have NO problem finding fellow "F" owners willing to do this.
I have 2 wheel drive.. and tow 9,000 pound trailer and would like 4.30's.
I tow twice a year. and truck is daily driver..
SECOND IDEA... just ADD larger wheels and tires.. problem solved..
Old Dec 1, 2017 | 11:49 PM
RainDesert's Avatar
RainDesert
OP- is your truck gas or diesel?
Old Dec 2, 2017 | 12:59 AM
seemoremud's Avatar
seemoremud
I would swap axles with you, and pay for the swap entirely if you were nearby. Shouldn't have a hard time finding someone near you to do the same
Old Dec 10, 2017 | 02:22 PM
00t444e's Avatar
00t444e
Is the truck Diesel or Gas? If its a gas truck then I would keep the 4.30s, if diesel then a 3.73 swap would give it better fuel mileage and it could still tow fine.
Old Dec 10, 2017 | 10:55 PM
Destroked 450's Avatar
Destroked 450
Tire height makes a big difference in gear selection.
I swapped from 4.88's to 3.73's and love them, but my tires are only 32" tall and my engine operates at a lower rpm.
Old Dec 11, 2017 | 04:57 AM
redford's Avatar
redford
FTE Leadership Emeritus
Have you looked into installing a Gear Vendor overdrive unit?
forced5
Sep 6, 2013 10:13 AM
ncl
2009 - 2014 F150
16
May 27, 2013 07:20 AM
Randallman
Modular V10 (6.8l)
Apr 10, 2013 07:36 PM
jkudera
Mar 18, 2012 12:16 PM
Silencer
Oct 9, 2008 06:10 PM
