HALP!!A different no start issue.
Old Nov 30, 2017 | 09:48 PM
Colorado350's Avatar
Colorado350
Originally Posted by BillyBob69
Ok so off to on 5 times stopping on ON. Then press unlock on the door then turn key to start?
Yes, BUT press unlock on the remote NOT the door. Turn key off and try starting with the key.
Old Nov 30, 2017 | 09:51 PM
BillyBob69's Avatar
BillyBob69
Hmmmm. Ok. I will dig up the original remotes. Have to say...this is a first I have heard of this procedure and I thought I had heard it all. ��
Old Nov 30, 2017 | 10:03 PM
BillyBob69's Avatar
BillyBob69
Just running things through my head...but is there a reset or some sort of safety shut off or “circuit breaker” for for the fuel system that could of been triggered by the sudden shut down from the remote starter?
Old Nov 30, 2017 | 10:09 PM
Colorado350
The remote start may be in Valet mode, this should take it out of VM.
IIRC, No.
Old Nov 30, 2017 | 10:38 PM
HD Rider's Avatar
HD Rider
On mine it you lock the doors with the button on the remote state fob, then use the key to unlock, it will disable the ignition. You must use the unlock button on the remote start fob to get it started.
Old Nov 30, 2017 | 11:07 PM
BillyBob69's Avatar
BillyBob69
Remember all. I have removed the remote start unit. It is an aftermarket that I installed about 8 or 9 yrs ago. Still have the same issue with it out. So...it may have caused the prob but it isn’t the issue now.
Old Dec 1, 2017 | 07:40 AM
Colorado350
I am referring to aftermarket in above post.
Old Dec 1, 2017 | 07:45 AM
BillyBob69's Avatar
BillyBob69
So put it back in, then run the steps you gave? I think I am lost.
The remote unit is pretty basic.
I did check and it is the CoolStart RS3-G5 (CrimeStopper)
I didn't even use all of the options. It is just wired for remote start and run the door locks.
I unplugged the unit completely from the truck and still get the same crank but no run.
I didn't even install the hood pin. And until yesterday, this think worked great for 9yrs. I think it still works, but something was triggered in the truck when it cut off power and stopped the truck and me turning the key to start it.
Right now the potteries are on a tender. I have disconnected the + leads from them and hooked up the tender. Been on there all night.
I will be digging into this more tonight after I get home from work and this weekend. Hope to get it going, I need to have this running this weekend. Need to get a load of hay.
Old Dec 1, 2017 | 08:30 AM
Colorado350
Billy,
Here's the manual, look on PAGE 19 DIAGNOSTICS for trouble shooting.
https://assets.sonicelectronix.com/m...7g5_manual.pdf
Old Dec 1, 2017 | 08:38 AM
BillyBob69's Avatar
BillyBob69
Billy,
Thanks for digging that up...but as I mentioned before, I have removed the remote start unit and the issue still exists. So to me, it is NOT the remote unit that is failing now. It may have caused something to fail, but it isn't the current issue.
I am trying to figure out what it could of affected.
I have the batteries disconnected and when I get home I will reconnect and try to start again. No remote unit installed, no chip.
after that I think I am going to have to start troubleshooting the fuel system.
I believe there is a relay somewhere that could of affected this but finding it is the trouble. All fuses under hood and under dash have been checked, but I have not tested the relays themselves. That will probably be next. I just hate going through all of them if someone knows which could be pointing to injectors or fuel.
Old Dec 1, 2017 | 09:04 AM
HD Rider's Avatar
HD Rider
Have you tried unplugging the ICP?
Old Dec 1, 2017 | 09:07 AM
BillyBob69's Avatar
BillyBob69
Not yet. That is on my list of things to try when I get home. I have a spare CPS in the glove box that is going to go in. The try ICP.
That is all after I verify that it is getting fuel.
I am at this point looking at... What could of puked from a sudden cut off of power to the ignition system.
If it is IPR...then I am going to claim coincidence.
I mean the truck is 19yrs old and almost 330K on the clock. Its about time those sensors were replaced anyway.
Old Dec 1, 2017 | 09:27 AM
  #28
Colorado350
I don't remember, Have you checked fuses?
Old Dec 1, 2017 | 10:00 AM
  #29
BillyBob69's Avatar
BillyBob69
Yep pulled each one and visually checked. I am going to pick up a fuse holder so I can do an actual continuity test on each one if I need to.
Old Dec 1, 2017 | 10:35 AM
  #30
Colorado350
I'd check the manual and see what it says, maybe call their tech department. I know you removed it but maybe it'll point you in the right direction.
