Cab corners and....
Old Nov 29, 2017 | 02:18 AM
crucialprospect's Avatar
crucialprospect
Cab corners and....
So I'm getting around to replacing the cab corners on my '86 regular cab. I got them in the mail today and took them out to sort of mock up. The passengers side looks fairly straight forward, although until I start removing metal and grinding will I see the full story. The driver side was a different story. Not only was there a rust hole on the cab corner, but it seemed to rot out a bit on what I've seen l listed as "lower door post." So I hopped on bronco graveyard and started snooping around and there are 2 listed, a front and a rear, the rear shows some sort of bolt along the lower valence, and the front actually looks more like what I need? I attached 2 pictures to show what I have, and what the patch panel covers. Any help would be appreciated! Also, is it good practice to cut down patch panels to only the needed size rather than cut the body out more than need be to patch? I'm looking at the easr of removing more metal vs whoops! I cut to much and that's the biggest panel they sell!
Old Nov 29, 2017 | 02:33 PM
FuzzFace2's Avatar
FuzzFace2
I am on my phone and will try and post when on my computer.
Dave - - - -
Old Nov 29, 2017 | 03:10 PM
crucialprospect
Thanks! What makes matters worse, I just got off the phone with jbg and the lower rear posts the sell don't go high enough to cover the spot on the rear door post where the rust hole is....
Old Nov 29, 2017 | 05:01 PM
Franklin2's Avatar
Franklin2
I am not sure what you are talking about. Were is the rust that is not covered by the cab corner patch? Just forward of the patch?
Old Nov 29, 2017 | 05:04 PM
Franklin2's Avatar
Franklin2
I have used #16 in the link below for 87-up trucks and it works well. Not sure why they do not offer it for the 86-dwn trucks.
Truck Parts and Truck Accessories
Old Nov 29, 2017 | 06:21 PM
crucialprospect
yes, where the patch fits to the lower door post.
Old Nov 29, 2017 | 06:26 PM
crucialprospect
not sure either, that's why I went to jbg to check it out, they have the rocker with the lip like shown on the later models, but my rust area is above the patch they sell.
Old Nov 29, 2017 | 07:57 PM
FuzzFace2's Avatar
FuzzFace2
I think this link should help with the part you need.
https://tabcoparts.com/60142.html
Here is the part being installed. You can also see where I marked the truck body with black marker where the top of the cab corner panel went before I trimmed it shorter. This way I knew how high I could go with out cutting into area not covered by the patch.
Dave ----
Old Nov 29, 2017 | 08:41 PM
crucialprospect
That's the same part jbg lists as well. I can't see good from your picture, but did it go high enough to weld into the rear pillar? What I'm seeing is there is the main pillar on the back of the cab, that transitions into that piece, and the cab corner overlaps from the rear. If I'm not mistaken, mine almost seems to be rusted higher than what that piece would cover. In which I will definitely get that piece, but I may have to fabricate another section to go higher. Looks like you've done some extensive work to your truck as well! Very nice!
Old Nov 29, 2017 | 08:48 PM
crucialprospect
I'll try to clean my corners up a bit tonight after work and get a better picture, I can see how it's misleading on what is rusted out and what's just dirty
Old Nov 30, 2017 | 02:41 AM
crucialprospect
Hopefully that gives a better view. It looks like the plate that goes over the rocker needs to be replaced and when I measured it, the rust stops around the 4 1/2" mark. If I can figure out how tall the replacement panel is and it's about that high I should be good.
rock2610d
Sep 21, 2017 08:43 PM
68bumpside
Mar 22, 2015 07:51 PM
Lakotas53
Dec 1, 2010 06:34 AM
goldswim5
18
Jul 9, 2010 10:36 AM
GQROD
Feb 17, 2010 11:30 AM
