Transmission Flush
Old Nov 28, 2017 | 12:23 PM
1L243's Avatar
1L243
Transmission Flush
A little history. I have owned my e99 2WD F250 since it had 22k on it (2005). Now, 12 years later it has 197k on it.
I installed a 6.0 trans cooler back in 2010. The transmission has never missed a beat and is working great. The trans has never overheated. The 6.0 cooler towing 12k even on the hottest day 165 degrees max (pillar gauge).
I have had the transmission flushed every 30K. The pan has never been dropped which means the filter has never been changed. I was told by two transmissions shops that it was not necessary to drop the pan and change the filter. They said "the filter is just a screen not really a filter". So, that is what I did.
The last time I had the transmission flushed I had Ford do it. Besides the flush they wanted to drop the pan and change the filter. For this, they wanted to almost double the cost of the flush. I thought they were just trying to rip me off so I said no.
Now, to my question. I am curious of the consensus on this forum to drop the pan and change the filter at each flush, or not?
Thanks for the input...
Old Nov 28, 2017 | 12:30 PM
Olds64's Avatar
Olds64
I wouldn't bother changing the filter every 30K miles. That's too often.
If you're truck has 197k miles on it and still has the original transmission filter you could have it changed. The best thing you have going for you is an auxiliary transmission cooler and regular fluid changes. Keep it up, especially if you tow often.
Old Nov 28, 2017 | 01:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The filter is a bit finer than a screen. It is also good for the life of the trans. There won't be enough trash in the filter to make it necessary to change it until the trans has failed.
KMAPRO
Jun 7, 2017 05:36 AM
1L243
16
Jun 25, 2016 09:25 AM
vettex2
18
Nov 12, 2015 08:13 AM
BWST
37
Dec 2, 2013 10:28 PM
Jay87LX
15
Sep 11, 2013 09:16 PM
