gear clank??
Old Sep 11, 2003 | 10:05 PM
hyperpunkguy[F150]'s Avatar
hyperpunkguy[F150]
gear clank??
i dont know if this has to do with my clutch again but when i release the clutch after shifting in to 2nd gear it makes a clank. what could this be? is it somethin i should fix?
Old Sep 11, 2003 | 10:36 PM
c_rossman's Avatar
c_rossman
gear clank??
Probably not the clutch if it only does it in one gear. It could be a worn slider in the transmission. Does it clank when you let off of the gas?
Old Sep 11, 2003 | 10:42 PM
hyperpunkguy[F150]
gear clank??
not sure but im thinkin it may.
Old Sep 12, 2003 | 07:44 AM
ewellman's Avatar
ewellman
gear clank??
Have you checked your u-joints. I had a similar plroblem. Heard a clunk when shifting into second. It turned out to be the rear u-joint was shot.
Old Sep 12, 2003 | 10:21 AM
stevieray's Avatar
stevieray
gear clank??
Are you sure that the clank is in the tranny? It could be coming from the rear end due to excessive baklash in the crown and pinion.This usually happens in a first second shift but when up to speed the backlash is not so noticable and road noise helps drown it out as well.
Old Sep 12, 2003 | 11:22 AM
hyperpunkguy[F150]
gear clank??
ok well i was listening while driving today and im pretty sure that it does this in 1st and 2nd. but it only makes the light clank noise when im making a hard turn. (usually when im at a stop sign and i make the turn. so im thinkin it has to do w/ my steering?
Old Sep 12, 2003 | 12:00 PM
stevieray's Avatar
stevieray
gear clank??
Try this. With the truck in neutral,engine off, parking brake on and wheels blocked, crawl under neath and twist the drive shaft by hand back and forth and listen for the clank. Also check the U joints for play.
Old Sep 12, 2003 | 10:42 PM
hyperpunkguy[F150]
gear clank??
ok but where are the U joints?
Old Sep 13, 2003 | 11:26 AM
stevieray's Avatar
stevieray
gear clank??
Depending on the length of your drive shaft you will have 2 or 3 U joints. One is right behind the tranny the other is just ahead of the rear end and if your drive shaft is the long type used in a club cab long box truck the third one is at the carrier bearing in the middle of the drive shaft.
Old Sep 16, 2003 | 09:38 PM
hyperpunkguy[F150]
gear clank??
ok i finally got a chance to look for the U joints but still dont know what they look like??
tecgod13
19
Feb 3, 2017 09:19 PM
Larossho
Dec 31, 2016 07:44 PM
NW 150
Oct 6, 2014 07:12 AM
belchfire
Jun 4, 2014 12:03 PM
epos48
May 17, 2007 12:15 PM
