White Smoke
Old Nov 26, 2017 | 08:08 PM
circllb's Avatar
circllb
White Smoke
New to this. 99 F350 Hard to start and White Smoke out of tailpipe
Old Nov 26, 2017 | 08:13 PM
Colorado350's Avatar
Colorado350
Is your Glow plug relay (GPR) working? Here's a video on how to test it.
It would help to know how many miles, any mods, anything you know about the truck, etc.
using Video Tube.
Old Nov 26, 2017 | 10:29 PM
Tedster9's Avatar
Tedster9
Think it means new Pope.
Old Nov 26, 2017 | 10:36 PM
Colorado350
Tedster9 9:29 shows a post, but nothing here. I remember Mark saying something about this...
Edit: Yup, there it is. But, I think Ted is worried about the Vatican though
Old Nov 27, 2017 | 06:57 AM
Walleye Hunter's Avatar
Walleye Hunter
circllb, your symptoms indicate bad glow plugs and/or glow plug relay (GPR). Checking the relay is easy and you can jump it with a screwdriver for a minute then try starting the truck when cold. Once warmed up it won't activate. Next you can ohm out your glow plugs through the connectors on the valve covers.
Old Nov 28, 2017 | 11:36 AM
Scotttex610's Avatar
Scotttex610
Is it cold outside, my truck smokes like crazy when it is cold outside. Sometimes I have to plug it in.
Old Nov 28, 2017 | 11:33 PM
circllb's Avatar
circllb
Now the truck has a knock in it. 318,000miles on the truck. I have never had to work on the motor.
Old Nov 28, 2017 | 11:35 PM
circllb's Avatar
circllb
We have a knock in the motor now, it has 318,009miles on it. Never have had to work on the motor.
Old Nov 29, 2017 | 05:13 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
First thought is fuel pump, especially if she was low on power beforehand. Key it on but do not start, you should hear the pump running for 20 seconds. It's mounted on the frame rail just beneath the driver door. Should sound smooth, not variable. Would be great to get fuel pressure from a gauge mounted to the fuel bowl, but that's kinda involved. Easier step; on the back of the fuel bowl you will find the yellow fuel drain lever. Follow the drain pipe to see where it exits near the right front tire. Open lever while pump is running and you'll get a healthy splash of fuel all over your Ariats if you're standing near there. A container under the pipe will help. If just a trickle of fuel pretty good sign it's the pump.
As to the knocking... have you been maintaining the coolant SCAs? Worth checking the oil for color/smell/level.
FWIW Tedsters reference is to the old school papal twitter.
rowekmr
Jan 19, 2013 08:09 PM
Tormz
Dec 14, 2011 07:21 AM
savage250
Nov 4, 2010 12:41 AM
Powerstroke-7.3
20
Dec 9, 2009 10:17 AM
PsD007.3
Jul 21, 2009 12:22 PM
