This oil change was a PITA....Simple it was not.
I had to do a very similar thing to the filter that was on my truck when I bought it. A few years ago I discovered that K&N was welding 1" nuts to the bottom of their filters and I have been using them ever since on all of my vehicles.
Even the 245K mile 2002 Mercury Sable that just won't die! It is the only car I know of that was hit by a deer. I did NOT hit a deer with the car, the deer hit the car. Nevermind that I was able to swerve at the last split second and the deer hit every panel and body part all the way down the passenger side. So, technically the deer ran into the car... Also, I have not washed it in about 6 years and it is looking mighty fine from sitting under the pine tree when not being driven.
Just sayin...
Glad you were able to get it off after destroying it. There is always that point of no return when dealing with something like this.
Just sayin...
My 02 always took snugging up with an oil filter wrench to prevent it from dripping. Hand tight never worked.
NAPA sells an oil filter wrench that is used with a ratchet and extension that is about 3" wide and can really grip the filter. When all else fails, that's what I grab as the larger surface area always works.
I gave up on the screwdriver through the filter after I had to help a friend remove the oil filter plate from an 84 camaro after the screwdriver trick, then the pliers and vice grips ended up removing all parts of the filter except the plate that was still screwed in place.
I used to have photos of the oil filter wrench here, but when the got rid of the user galleries and all the photos stored in them, those photos disappeared.
Man, that looks like it came off a Detroit! Detroits typically will throw the filters at you or refuse to give em up no matter what.
We have a couple sets of oil filter wrenches with three fingers on em at work that dig into the filter as you turn em, break nearly every time you use em, but they help us avoid what you had to do!
You remember if you prelubed the O-ring last time?
What a mess! Glad to see that you were able to get it off.
This said I've had my truck 10 years now and have always used the Motorcraft FL-1995 filter, I never use a wrench of any sort to tighten, I tighten it as tight as I can by hand only, never any leaks, never a problem to remove, usually have to use a strap wrench to remove but it comes off easily.
Funny, I've owned this truck since it was brand new. I've gone back and forth doing oil changes myself and having them done. First time in 16 years that this has been an issue.
Newest filter got a good amount of Rotella T6 on the O-ring. Hopefully not a repeat in a few months.
I use a simple Excel "log" to keep track of when I changed the oil and filter. Saves having to crawl under the truck to see. I also log things like antifreeze, trans and other fluids, along with date, mileage and notes. BTW, there are plenty of good Excel knock-offs if you don't want to pay for the app.
