Transmission
Old Nov 26, 2017 | 06:31 PM
lalberts's Avatar
lalberts
Transmission
I have a 2005 Ranger 2 WD automatic transmission. When I start climbing a hill the transmission shifts down way to soon as far as I am concerned. I would like to Push on the gas to climb these mild hills but the engine shifts down so soon and Revs awefull high to maintain highway speed. Does anyone else Have this problem? Is there a fix for it? Oh and my engine is a 3.0 v6.
Old Nov 26, 2017 | 07:44 PM
85e150's Avatar
85e150
How high does it rev?
Old Nov 27, 2017 | 11:08 AM
lalberts's Avatar
lalberts
It revs way high like 5000+. Like even if I wanna pass it kicks down Revs way high and really no gains to speed just a rev-in engine!
Old Nov 27, 2017 | 05:24 PM
85e150's Avatar
85e150
How long have you had the truck? Is this the way it always was or did something change?
What does your transmission fluid look like?
A downshift or two is to be expected, but 5000 rpm with no real acceleration is the sign of doom.
Old Nov 27, 2017 | 08:42 PM
racsan's Avatar
racsan
i hate that about automatics, had a astro van that would sometimes do that, would drop down 2 gears to 2nd when trying to pass someone, actually would slow down while the motor revved to the moon. it also had a delayed shift to 2nd when cold. ended up trading it before anything else happened. might try a fluid/filter change.
Old Nov 27, 2017 | 09:31 PM
78Broncoinpieces's Avatar
78Broncoinpieces
its even worse in a 4wd automatic truck. the 3.0 just doesn't have much torque at low or mid range RPMs.
what is your rear gear ratio? what size tires?
Old Nov 28, 2017 | 09:39 PM
Conanski's Avatar
Conanski
Automatics suck.. literally. They suck the life out of en engine. I have two 3.0 Rangers here and neither has much trouble climbing small hills without downshifting, the truck with 4.10 gears doesn't even lose any speed, both have manual transmissions.
Old Nov 29, 2017 | 09:37 AM
pawpaw's Avatar
pawpaw
^+1 on checking the tranny fluid level & condition & changing it if it's time.
If the fluid level & condition are ok ^+1 on did the problem come about suddenly after some event, or slowly over time.
Seeing as how this is a 05 diagnostic system that's rather sophisticated & monitors a lot of things, use, borrow, or come by the inexpensive ELM scan tool as discussed here https://www.ford-trucks.com/forums/1...-scantool.html as it can scan All of the vehicle computer/controllers like the tranny controller, for trouble code clues. Post All code Numbers, as they can help focus a trouble shoot. Let us know what you find.
RJ sheedy
Dec 16, 2016 12:10 PM
country2
Jan 1, 2008 11:52 AM
david49892
Oct 3, 2005 07:12 PM
MrV300xlt
Sep 26, 2003 11:02 AM
TimRob
Mar 18, 2003 12:09 PM
