Trying to remove my A-pillar and cannot figure out how to get it off. This is what is behind the trim caps. There is no head for socket or allen. Enlarge photo and you will see what I am talking about
It's an oddball size bolt like 7/32 or 5.5mm or something like that. Take out both bolts per handle then the trim should pull slightly up and out. That bolt looks rounded like someone was having trouble finding the correct size socket to use, so I'd replace it.
