5 speed trans upgrades
Old Nov 29, 2017 | 06:19 AM
d.pish's Avatar
d.pish
Also trying to figure out why im only getting 7mpg
Old Nov 29, 2017 | 08:42 AM
Eric Fullerton's Avatar
Eric Fullerton
That is concerning, the 4.9 usually is the mileage king in full size pickups, most folks getting at least in the teens. I've got 2, an '87 and a '96, & while I haven't locked it down to a number, it is to the point where buying gas is almost forgettable.
Old Nov 29, 2017 | 12:11 PM
Mudsport96's Avatar
Mudsport96
Start by pulling codes
Old Nov 29, 2017 | 05:45 PM
d.pish's Avatar
d.pish
only code im pulling is a P0113 which is intake air temp sensor
Old Nov 29, 2017 | 05:49 PM
d.pish's Avatar
d.pish
your telling me ive only driven 112 miles and ive used a little over 3/4 of a tank
Old Nov 29, 2017 | 09:35 PM
Mudsport96's Avatar
Mudsport96
if start there, not sure if that sensor has so much of an effect, but if its showing bad put a new one in
Old Nov 29, 2017 | 09:46 PM
Eric Fullerton
The ECU uses the air intake sensor to read incoming air temp. If the sensor is bad and/or is in the stream of hot air, it may make the motor divert to preset rich fuel map (poor performance) to reduce detonation, that could seriously reduce MPG
Old Nov 29, 2017 | 11:29 PM
andym's Avatar
andym
Sounds like the crossflow fuel problem to me. Two separate tanks?
In the future, you should know that going by the gas gauge on the dash to calculate or even estimate mileage is a complete waste of time. You hand calculate it by measuring miles and gallons or it's not worth doing at all.
Old Nov 29, 2017 | 11:42 PM
GoinBoarding's Avatar
GoinBoarding
He has another thread focusing on this fuel consumption issue. It's a short box single tank truck.
https://www.ford-trucks.com/forums/1517867-96-f150-4-9-poor-mpg-issue.html
Old Nov 30, 2017 | 06:34 AM
d.pish's Avatar
d.pish
thats how i figure it is miles and gallons, and no just 1 18 gallon tank.
Roger T. Pipe
Oct 22, 2009 01:23 AM
stiffnecked
May 26, 2007 05:52 PM
BlackFX4Screw
2004 - 2008 F150
17
Mar 11, 2006 07:56 PM
AxisAllies
Oct 11, 2004 09:58 PM
Bandito1961
Jan 21, 2004 09:54 PM
