Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
quincy 310 compressor unloader problem
Old Nov 16, 2018 | 12:13 PM
  #31
jniolon's Avatar
jniolon
old and in the way
so next to the pneumatic unloader... broke it down and here's what I found
gasket looks decent ...no obvious signs of breaks or leaks (although it could be porous enough to pass air
here;s the other guts
the body of the unloader... should the piston seal surface look this rough ??
other pieces
anyone got a diagram or cross section drawing of this unloader valve ??
john
Old Nov 16, 2018 | 12:31 PM
  #32
Brownac1983's Avatar
Brownac1983
john
This is for a 325, but it should be pretty much the same.
https://manualzz.com/doc/8323519/qui...325-parts-list
Old Nov 16, 2018 | 12:38 PM
  #33
jniolon's Avatar
jniolon
old and in the way
so ??? see any major problems from my pictures ???? since I can't reliably test diaphram should I just go ahead and replace it ?
  #34
Brownac1983
What you need to determine now is where the air is coming from. Put the pneumatic unloader back together and try to blow in the nipple on top. You shouldn't be able to push air through it. If you can, the diaphragm is leaking by.
Old Nov 16, 2018 | 12:39 PM
  #35
Brownac1983
That one has some wear so I'd plan on replacing it soon regardless, but we need to determine if that's the actual problem. Everything else looks pretty normal. Put it back together and see if you can blow air through the nipple on top of the unloader. You shouldn't be able to.
Old Nov 16, 2018 | 01:20 PM
  #36
jniolon's Avatar
jniolon
old and in the way
is lung power gonna do it... cause you know ??? my compressor is down
Old Nov 16, 2018 | 01:25 PM
  #37
Brownac1983
Hahaha... yeah, you're just looking to see if air will pass through one of those cracks in the diaphragm. Sometimes you can't tell by looking.
Old Nov 16, 2018 | 01:54 PM
  #38
Brownac1983
Another check, start the compressor while you have that copper tube off of the pneumatic unloader. Hold your thumb over it. You'll feel pressure building. What should happen is, once oil pressure builds (just a few seconds), air should stop coming out of that tube and you should be able to take your thumb off of it and nothing should come out. That's controlled by the hydraulic unloader. If the compressor runs and builds pressure for more than about 30 seconds and there's still air coming out of that tube, we need to go back and look deeper into oil pressure and the hydraulic unloader.
Also, with the tube off of the pneumatic unloader, if air still vents from the pneumatic unloader we need to look deeper into it, it'll be malfunctioning.
Old Nov 16, 2018 | 02:14 PM
  #39
jniolon's Avatar
jniolon
old and in the way
well, Brown... I've never been one to not admit my shortcomings or failings.... but it is embarrassing. blew on the unloader and no air leaking. So, I put it back on the pump and started it up... still blowing by,,,shut it down and for the hell of it pulled out the dipstick... know where I'm going ???? oil level was at the bottom of the safe (cross hatched mark) limit on the stick. Filled the oil back up to the full mark and restarted.. 10 minutes later and it shut off at 115 psi Don't tell anybody I did this !!!!! Thanks for all your patience and help... now ?? where did the oil go ??? another problem for another day...
thanks again...
John
Old Nov 16, 2018 | 02:51 PM
  #40
Brownac1983
No worries, that's what the hydraulic unloader is there for. Glad you got it going.
Hey, one more thing... last time we couldn't find good manuals for your compressor. I checked again and it looks like Quincy has really stepped up their game with the older manuals. Download these.
https://www.revbase.com/TagTeam/clie...ID=2&OrderID=0
Old Nov 16, 2018 | 03:01 PM
  #41
jniolon's Avatar
jniolon
old and in the way
it's asking fior an account name and password ??
Old Nov 16, 2018 | 03:16 PM
  #42
Brownac1983
That's weird. I just emailed the .PDFs to the address on the website in your signature.
-Drew
Old Nov 16, 2018 | 03:41 PM
  #43
jniolon's Avatar
jniolon
old and in the way
I got them in email... thanks for the books I always like to have a manual on what I'm breaking !!! and thanks again for the help... sometimes you can't fix stupid though
j
Old Nov 16, 2018 | 03:42 PM
  #44
Brownac1983
j
No problem, anytime.
Old Nov 17, 2018 | 09:56 AM
  #45
FuzzFace2's Avatar
FuzzFace2
Good to hear you got her working again.
As for where did the oil go?
I see on mine it has a film all around the compressor pump and top of the tank (stand up tank). Also I know some makes it by the piston rings and into the tank.
I have not seen oil in the water when I drain the tank but I know it is there.
IIRC when looking into mine I found if you had dirty air intake filters it could make it use oil, so check them, I know I have not since I got it running.
Over the weekend I had my compressor running to blow up tires and saw my oil level when running, sight glass, was on the low side of safe also.
I really should change it as I have not done so in some time, just don't know where I put the compressor oil when I moved!
Dave ----
