Revised ABS Thread
Old Nov 24, 2017 | 12:27 PM
sandymane's Avatar
sandymane
Revised ABS Thread
Now after I posted this revised info below. I cleaned the brake switch on the pedal and the RABS light is out now. The cruise control is still not working. Any ideas of how to correct this now? Thanks Sandy
My Cruise control was not working yesterday and has previously worked fine. I noticed that the ABS light was on. My Ford reader shows no codes in KOEO, I have no check engine light, KOER test only shows code 225 which is knock sensor and dismiss if not pinging which it isn't, So now I have no codes or check engine only the ABS light. I have done a couple of panic stops and no lock up so it seems to be working, Brake fluid is MAX.
I don't really know what to check or where to start with this issue. Any advice is appreciated. The recall pertaining to the ABS has not been done but has never been an issue with 150K miles. Thank you Sandy
Old Nov 24, 2017 | 03:16 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Does your red idiot light work for the brakes? Does it light when you turn your key to the "on" position? When you apply your parking brake?
Old Nov 24, 2017 | 03:35 PM
sandymane's Avatar
sandymane
yes and horn works key off and motor running and brake Tail lights work
Old Nov 24, 2017 | 04:33 PM
CMerr's Avatar
CMerr
I have a '96 F150 and my cruise stopped working it was because the sensor on the master cylinder went out and I didn't even know. I just went and had the recall work done and that fixed it. but it was fine one day and then nothing the next.
Old Nov 24, 2017 | 04:50 PM
sandymane's Avatar
sandymane
I ordered the correct recall replacement Motorcraft sensor today on Amazon. I have no idea if mine is bad or not but I want to prevent the fire potential of the old one. It was $13.00 and comes with the new harness. I would rather replace mine than take it to a dealership. In fact I would rather have a root canal than take my truck to them. thanks for your reply. Sandy
Old Nov 25, 2017 | 08:32 AM
rla2005's Avatar
rla2005
You cannot read RABS codes with a code reader. Two completely different systems that do not communicate to each other.
RABS Codes
courtesy of Steve83
Old Nov 25, 2017 | 11:43 AM
sandymane's Avatar
sandymane
RABS Codes
courtesy of Steve83
Thanks Randy. The RABS light went off by using contact cleaner on the switch and contacts on the brake pedal. I cleaned the cruise switches on the steering wheel. and I have no lights or codes and the Cruise still does not work. Perhaps the replacement sensor on the Master cylinder for the recall will fix it, but I am not to optimistic about that but it's a start. Do you have any suggestions for things to check? Brake fluid is full and fresh I have replaced all parts in both drums several thousand miles ago. Truck is running absolutely great thanks to you and others. Any advice from you will be greatly appreciated. Sandy
cthn7d
Oct 17, 2023 09:59 PM
maryjo21
Feb 17, 2017 09:18 PM
ozdatman
Jun 29, 2013 10:43 AM
PPrash
Aug 9, 2010 11:06 PM
ttttmaxx
22
Feb 16, 2009 06:29 AM
