4WD Issues
About 2 months ago I had a 2" leveling kit installed on my truck. When I left the shop I noticed a humming on my front driver side tire, a few miles down the road I heard a pop and the sound went away. Long story short I did some reasearch and narrowed it down that my IWE system was possibly damaged from the shop since I didn't have any issues with this before. I ran a few tests, switched my truck into 4H and back to 2WD, humming was back but went away shortly. During this time I also noticed a loud rattle from the same tire. And I have also noticed that if I hit a hard bump or accelerate quickly the humming comes back. In the two months since the install the humming has happened about 10 times but goes away within a few minutes or when I stop and start back but the rattle has stayed. That's my first problem.
Second problem. I was driving on some muddy roads, stopped and switched to 4L and everything engaged fine no issues. Drove about a mile, tried to switch back into 2WD while stopped. I got the "shift delayed, pull forward message" So I switched into drive and hit the gas but I didn't go anywhere. Switched back to neutral and back to drive and still couldn't move. I turned the switch back to 4L and back to 2WD. All of the sudden I heard a loud whinning noise and then a loud bang and the truck jumped. I was now in 2WD. Started driving and the humming from above was back but went away quickly. Ive tried shifting into 4WD since and the same thing happens every time I switch into 4L. However switching into 4H everything is fine.
Here are my thoughts.
1. Both problems are related and stem from an issue with the IWE or check valve
2. Bad iwe or check valve AND a t-case issue (motor or t-case itself)
I hope its my first thought, I've never had any issues with my 4WD system until that install and the original humming noise.
Any thoughts?
What was the fix? Having same issue.
