F100 with CV Rear End Question
Hello all, I mounted my 2005 CV rear end in my '64 F100 today. The 2017 Mustang wheel and tires I bought are to wide and rub the rear fenders.
I have one CV steel wheel and it fits. My question, has anyone else installed the CV rear end with Mustang wheels that fit?
If so what year, size, style???
Thanks in advance, Pat
Pat you've seen mine. Supposedly a 2001 CVPI rearend. I don't know if there's a width difference between the two years.
The wheels are 17" Bullitts. I'm not sure where they came from. They have Ford center caps so I'm guessing they're not aftermarket, but there's no way to really know.
The tires are 235's so I wouldn't think the wheels would be much larger than 7". I do have enough room in the back to go to 245 tires.
Hey Mike, I can't tell you how disappointed I am with the tires rubbing. They are 235/55R17, 7 inch wide, so the only thing I can figure is the offset on 2017 rims isn't as much as a little older rim.
I have since picked up 3 more CV steel wheels with tires so I do have rollers for now and if need be that's what I will run in the end. I've had a couple of guys suggest going with a different rear end but the one I have has just 46,000 miles so I'm staying with it for now.
On a side note we have the front suspension resting in place and are deciding how far forward to put it. We set the front fenders in place today and right now we feel moving the center point 1 inch forward from stock looks pretty good.
See ya later...
See ya later...
The Explorer 8.8s are very close to the same width as the stock 9 inch from a slick. 98-02 Crown Vics i've heard are a couple inches more narrow than the 03 and up Crown Vic 8.8s.
ajc7ny
01-31-2011 10:38 PM
BikerDude
01-16-2009 10:14 AM
