Wheel questions
Old Jul 9, 2016 | 11:41 PM
Psyclopse's Avatar
Psyclopse
Wheel questions
I'm normally in the Excursion and Super Duty forums, but if everything goes as planned, I'll soon have a 70 I6/3 on the tree.
We went and looked at it, and the tires are shot. After looking at various pics here, I'm considering either 235 or 245/75/R15 for tires. What I can't seem to find an answer for is aftermarket rims (backspacing/offset).
I'm aware of the rear track difference, but I really want the same setup on all four corners for a proper rotation pattern. What should I be looking for as far as wheels go?
Old Jul 10, 2016 | 12:06 AM
HIO Silver's Avatar
HIO Silver
Typically, 15x7 or 15x8 with zero offset.
If you want to correct the visual anomaly of these rigs crabbing down the road due to the narrower rear track width, opt for tires that are wider in back. I know that goes against your goal but that's one way. The other is to spec a 3-inch back space for the rear wheels to push the wheel/tire combo closer to the rear fender lip.
Here's my rig with 275/60-15s in back on 15x8 and 225/70-15s in front on 15x7s... all with zero offset. The tires are of the same diameter but different width and aspect ratio. It is lowered with DJM beams in front (-3) and an axle flip in back (-5) so it sits level.
Old Jul 10, 2016 | 12:39 AM
ultraranger's Avatar
ultraranger
The other alternative, if you want to have the same dimensions on the wheels/tires to be able to fully rotate them for longer tire life, is to install a Dentside or Bullnose 9-inch rear end.
It will put the rear wheels at the same track width as the fronts and you'll be able to install the same width tires and wheels all the way around.
You'll need to move the leaf spring perches and lower shock mounts inward on the Dentside/Bullnose 9-inch rear end housing tubes by 2" per side to line up with the Bumpside leaf springs and rear shocks.
Old Jul 10, 2016 | 07:51 AM
Psyclopse's Avatar
Psyclopse
After hours of reading in this section last night, I think my future plan (second mod, after the new wheels/tires) would be to change the rear end.
Is the rear end the same minus width, meaning same driveshaft?
If I went with one of the tire sizes I mentioned on a 7 or 8 inch wide rim (zero offset), would it still work with the original rear (no rubbing) until I can get it changed?
Thanks for the advice.
Old Jul 12, 2016 | 12:36 AM
Psyclopse's Avatar
Psyclopse
I guess I'll know tomorrow if I get to bring it home.
SoCal69
Jun 6, 2019 05:06 PM
Baddog671
Dec 25, 2014 10:36 PM
Shadowrider123
Jul 24, 2014 12:35 PM
Perry55
May 19, 2014 05:35 PM
davidmoss1992
16
May 1, 2012 10:35 PM
