Installed a Secure-Idle kit today
Old Nov 20, 2017 | 02:28 AM
90pioneer's Avatar
90pioneer
Finally got around to installing a Secure-Idle kit that I ordered a couple weeks back.
Overall the install went pretty smooth. Took me a bit to find the wire connector that I needed to splice into. Had thought it would have been under the dash but it was actually under the trim that surrounds the steering wheel.
The factory wires are small... much smaller than the wires on the secure idle kit. Keep this in mind. I used butt connectors and wire taps (yeah I should have soldered but don't have a solder gun).
Ran a ground wire, connected the last wire to the blue/grey wire in the accessory pack, drilled a hole in the switch and put everything back together.
Works great! Took me a while to figure out how to shut the truck off. The only way I can turn it off is by shifting out of park. Even if the key is back in the ignition. Not really a big deal. Factory remote start still works as normal along with my BD diesel high idle kit.
Will be nice this winter. It's already been down to -20.
Old Nov 22, 2017 | 01:21 AM
Dakster's Avatar
Dakster
Glad you got it done.
Old Jan 30, 2026 | 05:05 PM
madmedic8526's Avatar
madmedic8526
I know it’s a super old thread but where did you order the kit from? I’m looking to add this to my ‘22 6.7. I would love to keep the truck and AC running in the summer for my dogs while I run into the store while on the road
Old Jan 30, 2026 | 06:10 PM
speakerfritz's Avatar
speakerfritz
great job enjoy...next time give us couch potatoes some pics
Old Feb 2, 2026 | 01:00 PM
Overkill2's Avatar
Overkill2
Here you go...
SECURE-IDLE - Maximum Control, Elite Protection
Secure-Idle Ignition Override System – Arrowhead Safety Group
Old Feb 3, 2026 | 10:27 AM
jollyrogr's Avatar
jollyrogr
So this basically allows the vehicle to keep running without the keys in it? If you shift out of park it shuts off? Seems more geared toward a first responder application. I just installed a kill switch for theft protection. If the switch is off the truck won't start even with the key.
Old Feb 3, 2026 | 10:46 AM
madmedic8526
How does the kill switch work? What I am looking for is for the vehicle to remain running for my dogs while I run into the store while on a road trip.
Old Feb 3, 2026 | 06:39 PM
jetpilot2's Avatar
jetpilot2
Veteran: Navy
I'm not sure if the XLT has FOB or Key, but doesn't the '22 already have Secure Idle enabled? It does not allow the transmission to shifted out of park without the FOB.
Old Feb 3, 2026 | 09:01 PM
madmedic8526
Mine is keyed
Old Feb 4, 2026 | 09:50 AM
jollyrogr's Avatar
jollyrogr
You might be interested in the secure idle then. A kill switch simply breaks the ignition circuit so a thief can't start your truck.
Old Feb 4, 2026 | 11:41 AM
madmedic8526
I ordered a secure idle kit yesterday. I was just wondering about the workings of a kill switch. I have a curious mind.
Old Feb 5, 2026 | 01:20 PM
jollyrogr's Avatar
jollyrogr
It's just a simple switch installed in the ignition circuit.
65fordguy
Dec 14, 2013 03:52 PM
wolfe1104
24
Apr 7, 2008 09:51 PM
superdutyquest
Jun 22, 2006 10:04 PM
Hotwheelbill
Apr 24, 2006 09:21 PM
snipa
19
Mar 1, 2005 09:10 PM
