Sponsored by: Real Truck
5.4 3v engine quit while driving after phaser replacement
Old Nov 18, 2017 | 08:32 PM
jchandul's Avatar
jchandul
So I replaced both phasers, timing components and oil pump on my 2005 F250 5.4l 3v. Upgraded the oil pump with a Meiling M360. Used the Ford crankshaft holder to align the crankshaft. Primed the engine with the crankshaft sensor disconnected. Connected the crankshaft sensor, engine fired up immediately. No drivetrain noises. Engine idled perfectly. Let engine come up to operating temp. Upper rad hose warm, heat from vents. Took truck for test drive. Stumbled a few times on acceleration. Then engine quit. Would not restart. No crank. Starter engages but will not turn over engine. Sounds like engine is locked up. No check engine light on prior to engine quitting.
Any thoughts on where I should start to look? Thanks
Old Nov 18, 2017 | 09:01 PM
Djosbun's Avatar
Djosbun
What did you use for the oil pump pickup? The original pickup or one that came with the Melling pump? If you used the Melling pickup, did you check for pan clearance? I’ve seen pump pickups that actually touched the bottom of the oil pan.
Can you turn the engine over with a breaker bar? If not, quite possibly the pickup is lying in the bottom of the oil pan. I do not know how the Ford pickup attaches to the oil pump, though. Is it bolt on or interference/press fit? I always tack weld the press-in types.
— Dave
Old Nov 18, 2017 | 09:23 PM
jchandul's Avatar
jchandul
Dave. I used the existing oil pickup. The oil pickup is bolted to the oil pump. I’ll try turning over the engine tomorrow with a breaker bar and update this post.
Old Nov 19, 2017 | 01:33 PM
jchandul's Avatar
jchandul
So the engine will turn over with a 24” breaker but it takes a lot of effort. The starter will turn the engine but only a few turns and very slow rpms. There’s a lot of draw on the battery.
Old Nov 19, 2017 | 07:47 PM
Djosbun's Avatar
Djosbun
Do you have a spare battery that you can try? Maybe jump start it?
— Dave
dtmtkq
Jul 1, 2011 08:26 PM
newbe-rebuilder
Sep 8, 2008 02:09 PM
grizz3000
Dec 20, 2006 12:05 AM
ghz
Dec 17, 2005 06:08 PM
pdm
May 13, 2003 03:14 PM
