4.9L No Start
Old Nov 18, 2017 | 05:06 PM
evan_nugget's Avatar
evan_nugget
4.9L No Start
Hey all. I've searched the forum and found a bunch of people with the same problem but they are missing a critical symptom that my truck has. Just today I tried to start my '96 F-150 (4.9, 5 spd) and it will make one distinct CLICK and then nothing! But here's where it gets weird. After the click, the truck has NO ELECTRICAL POWER. No dash lights, no fuel pump, no cab lights, no power. By wiggling the negative battery cable connections to the battery I can restore electrical power (dash lights, fuel pump, dome light) but when I try to crank it over the same thing happens. In the past, I have been able to wiggle the negative battery connection and get the truck to start, but this time it isn't working. The truck does have a new battery, starter solenoid, and starter put on BEFORE these symptoms started.
Anyone who can give me some leads to try, I'd be very grateful. Will be checking ground straps after posting this, but I haven't run across anyone with the no start no electrical power issue that I have.
Thanks all, Evan
Old Nov 18, 2017 | 05:32 PM
stephandrusty's Avatar
stephandrusty
Clean your battery connections . Check and clean ground connections. Replace battery cables . Try that for a start. Good luck.
Old Nov 18, 2017 | 05:36 PM
88n94's Avatar
88n94
Another one of these. Make sure the connections on the battery posts are CLEAN and TIGHT. Remove the cables from the battery posts and clean the inside of the cables where they go on the battery posts and also clean the outsides of the battery posts. Then make sure they tighten up properly.
If that doesn't solve your problem look to the other battery cable connections,cleaning them and make sure they tighten properly.
Old Nov 18, 2017 | 10:37 PM
vjsimone's Avatar
vjsimone
Like stephandrusty states, replace the Neg Batt cable to start with.....
Old Nov 19, 2017 | 01:38 PM
evan_nugget
Thanks for the help all! I feel a little stupid - it was just the battery cable ends, specifically the positive terminal end. I cleaned them up and replaced the clamp style with some solder on terminals and it starts great. In my defense, this is my first time working with vehicle electrical systems, Im slowly learning!
Old Nov 19, 2017 | 07:56 PM
vjsimone's Avatar
vjsimone
Well done for doing it yourself.........
Old Nov 20, 2017 | 12:48 AM
'89F2urd's Avatar
'89F2urd
Yes this was an easy one...but...live and learn, it's all part of the game.
Old Nov 20, 2017 | 12:37 PM
mark1986F150's Avatar
mark1986F150
You'll feel like a genius when you help someone with the same problem and you provide them the simple solution.
Nice job.
blue76
Jul 1, 2016 07:23 PM
danfarrands
1983 - 2012 Ranger & B-Series
Dec 25, 2008 10:54 PM
ford4her
Electrical Systems/Wiring
18
Aug 21, 2007 02:15 PM
RAK1
Nov 23, 2003 06:35 PM
iamme9182
Sep 26, 2003 04:33 PM
