Parts Help Request
Old Nov 16, 2017 | 12:51 PM
Dman130's Avatar
Dman130
Parts Help Request
Has anybody walked this mile trying to find one of these that is not broken, or a method to repair? It's for my 86 F150 XLT
Thanks in advance,
Tom
Old Nov 16, 2017 | 08:01 PM
Franklin2's Avatar
Franklin2
I pulled one from a car and retro fitted it in my truck. Ford used these things for years in most of the cars and trucks.
It's #4 in this link correct?
Truck Parts and Truck Accessories
Old Nov 16, 2017 | 08:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E3TZ-7A110-A .. Transmission Control Selector Indicator-Use with AOD / Obsolete
1983/86 F100/150 & Bronco.
No Ford dealer or obsolete parts vendor has any.
Old Nov 16, 2017 | 09:11 PM
reamer's Avatar
reamer
I got lots of them.........
Old Nov 17, 2017 | 08:03 AM
Dman130's Avatar
Dman130
Thanks Gentleman for your insight to the trans indicator search, Dave your correct about #4 but they don't have the AOD option, Bill your also correct that it is obsolete and there is no vendors with any inventory. Which leads me to "reamer", seriously? You have lots of them?! Let's work something out please.
Tom
Old Nov 17, 2017 | 09:50 AM
neoniacin's Avatar
neoniacin
LMC link says it isn't available when I clicked on it.
If you can't find one could you Frankenstein one together from your old one and this?
https://www.ebay.com/itm/80-86-F150-...-/263293865243
I had mine break too but I don't have AOD.
Old Nov 17, 2017 | 02:25 PM
Franklin2's Avatar
Franklin2
I am trying to think how you could splice that tube back together. There is nothing in it but string. If you could undo the string on one end or the other, then you could slip something over it like shrink wrap, or maybe superglue a piece of vacuum hose over it and slide the tubing together. Then thread the string back through.
Old Nov 17, 2017 | 06:02 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
You could use a piece of the plastic 1/8 inch oil line tube for an aftermarket guage. Or use the 1/8 copper, never break again.
Old Nov 28, 2017 | 09:36 AM
Dman130's Avatar
Dman130
Can you sell one to me please?
Old Sep 29, 2018 | 11:18 AM
SB1984's Avatar
SB1984
E3TZ-7A110-A
reamer I am in need of a E3TZ-7A110-A Shift Indicator for my sons 1984 f150. If you still have lots of them I’d like to make contact
Old Sep 30, 2018 | 06:09 PM
Old Hickory's Avatar
Old Hickory
A few years ago I had the same problem. I got a C6 /C4 type from LMC which was a genuine Ford part and removed the cable from it and fitted it to
my AOD indicator and it worked fine.
ToddOuzts
May 16, 2017 10:19 PM
N.W.Ford
Nov 24, 2014 01:02 PM
spikinfool05
Apr 19, 2014 03:22 AM
peytonkristen
Dec 13, 2010 02:44 PM
jtod
1978 - 1996 Big Bronco
Feb 16, 2002 10:02 PM
