Use vacuum hose only as a temporary fix.
The hose is not formulated for crank case contaminants.
The rubber ELL at the rear of the intake already goes bad from them.
It usually causes codes 171/174 from letting outside air into the motor through the port on the back side.
Do proper repair.
Good luck.
Do proper repair.
Good luck.
thanks, where do you get the rubber ell? Ford house
