I have an 2016 F-250 Super duty Ford. My running lights on trailer don't work. My break stop and singles works fine. I looking where and what fuse number should I be looking for.
If it’s not your fuse....check the seal on the plastic harness. Had the same issue 2 weeks ago and the clip that holds the harness in had broken and everything was corroded. Had to replace the entire harness and whip with the connector.
It's all new wires and harness. I have 12 volts on my break and single light at my truck but not getting any voltage for my running lights.
The first place I look when trailer lights act weird.........check all GROUND connections.
To the OP, is this still an issue or resolved? If still an issue are you measuring with volt meter or going off what trailer lights are doing? Do you have another trailer you could use for testing? Is this the only trailer you have hooked up on this vehicle thus far? Only addition is to check for a relay 29, is it there, if so I’d swap with 30 or 31.
