Best Way to Disconnect Fuel Bowl Heater?
I am trying to disconnect the Fuel Bowl Heater on a '99 PSD (F250) in order to troubleshoot why the Wait to Start light is not illuminating and engine not starting.
Is the best way to unplug on the OUTSIDE of the filter housing? If so, how does that plug come out? I have tried several time and cannot figure out how to get it loose? Sorry if this is obvious but that is just me.
Thanks for any suggetions.
Anyone know how it releases? It has been connected for 18 years and stiff!
It's just your standard electrical connector. Spray it with electrical connection cleaner to get the dirt cleaned out. Then give it a taste of WD40, once you have it removed, clean it again with electrical cleaner. If I remember correctly you said you're going to reinstall it eventually. I would put a little electrical tape to keep the dirt and grime off of it until you're ready to re-hook it up.
Why does the Number 30 fuse keep blowing? I filled the fuel bowl with Diesel to keep the heating element submerged. So, it should not be overheating. This may be a worn out heater element although it appears to be fine. I see no obvious signs of melting at the contacts. Anyway, this is a separate issue from the Fuel Pump or PCM question.
Success!
Once I got the clip off the Fuel Bowl Heater, the WTS light came back on. Pump seems to run fine. I just could not hear over that bell. Neighbor got underneath and could hear the pump.
Tapped off the plug and receptacle.
The problem may be the Fuel Bowl Heater with a short. This needs to be replaced. For the past two winters there have been periods of about ten days during our coldest below Zero (F) nights when the truck would not start. This despite the block heater being plugged in overnight. So, it is possible the Fuel Bowl Heater just was not functioning. Replaced that Block Heater last month.
Hope this concludes the issue. Now recharging the batteries depleted from failed starts.
Thank you one and all for your kind assistance.
You are in a warm section of the country.
Remove the fuel bowl heater. Reassemble the fuel bowl without a heater. You will never have this problem again.
*I removed the heater from mine years ago, and have never had a problem since removal.*
What makes you say Northern NM is a warm section of the country? I was there in July and we had hail and 40 degree nights. I've been there at Christmas and it was near zero at night with ice everywhere.
It is in a similar latitude to my area, and the Carolinas are warm to me, including the mountains.
How effective do you think that heater is in fuel anyway? Think about it.
Good and functioning glow plugs get the engine running, not the bowl heater.
Success!
Full synthetic oil is great for starting in cold conditions.
Wanna get rid of that annoying chime?
