Best Way to Disconnect Fuel Bowl Heater?
I am trying to disconnect the Fuel Bowl Heater on a '99 PSD (F250) in order to troubleshoot why the Wait to Start light is not illuminating and engine not starting.
Is the best way to unplug on the OUTSIDE of the filter housing? If so, how does that plug come out? I have tried several time and cannot figure out how to get it loose? Sorry if this is obvious but that is just me. Thanks for any suggetions. |
Just unplug it at the rear of the bowl, can't help with exactly where the release is on the connector.
Originally Posted by Walleye Hunter
(Post 17588783)
Anyone know how it releases? It has been connected for 18 years and stiff! |
It's just your standard electrical connector. Spray it with electrical connection cleaner to get the dirt cleaned out. Then give it a taste of WD40, once you have it removed, clean it again with electrical cleaner. If I remember correctly you said you're going to reinstall it eventually. I would put a little electrical tape to keep the dirt and grime off of it until you're ready to re-hook it up.
Originally Posted by Colorado350
(Post 17588831)
Why does the Number 30 fuse keep blowing? I filled the fuel bowl with Diesel to keep the heating element submerged. So, it should not be overheating. This may be a worn out heater element although it appears to be fine. I see no obvious signs of melting at the contacts. Anyway, this is a separate issue from the Fuel Pump or PCM question. |
Originally Posted by Flame Out
(Post 17588863)
Just wanted to be clear on that plug. I hate breaking parts!
Why does the Number 30 fuse keep blowing? Is this because the fuel bowl is empty with no fuel supplied by the pump and overheats? |
Success!
Once I got the clip off the Fuel Bowl Heater, the WTS light came back on. Pump seems to run fine. I just could not hear over that bell. Neighbor got underneath and could hear the pump. Tapped off the plug and receptacle. The problem may be the Fuel Bowl Heater with a short. This needs to be replaced. For the past two winters there have been periods of about ten days during our coldest below Zero (F) nights when the truck would not start. This despite the block heater being plugged in overnight. So, it is possible the Fuel Bowl Heater just was not functioning. Replaced that Block Heater last month. Hope this concludes the issue. Now recharging the batteries depleted from failed starts. Thank you one and all for your kind assistance. |
(Post 17589136)
...Fuel Bowl Heater with a short. This needs to be replaced...
Remove the fuel bowl heater. Reassemble the fuel bowl without a heater. You will never have this problem again. *I removed the heater from mine years ago, and have never had a problem since removal.* |
Originally Posted by dn29626
(Post 17589152)
You are in a warm section of the country.
Mine Failed several years ago. I unplugged it and never thought much about it. Pulled the engine from truck number 1 and now it is in truck #2 with no problems over several winters. I do use the power service white bottle in the winter.
what are the requirements for it to be turned on? |
Originally Posted by bigb56
(Post 17589298)
...What makes you say Northern NM is a warm section of the country...
How effective do you think that heater is in fuel anyway? Think about it. Good and functioning glow plugs get the engine running, not the bowl heater. |
(Post 17589376)
It is in a similar latitude to SC. SC is warm to me.
(Post 17589376)
Good and functioning glow plugs get the engine running, not the bowl heater. Yes but I thought the purpose of the fuel bowl heater was to prevent or melt gelled fuel. |
(Post 17589136)
Success!
Once I got the clip off the Fuel Bowl Heater, the WTS light came back on. Pump seems to run fine. I just could not hear over that bell. Neighbor got underneath and could hear the pump. Tapped off the plug and receptacle. The problem may be the Fuel Bowl Heater with a short. This needs to be replaced. For the past two winters there have been periods of about ten days during our coldest below Zero (F) nights when the truck would not start. This despite the block heater being plugged in overnight. So, it is possible the Fuel Bowl Heater just was not functioning. Replaced that Block Heater last month. Hope this concludes the issue. Now recharging the batteries depleted from failed starts. Thank you one and all for your kind assistance. Full synthetic oil is great for starting in cold conditions. Wanna get rid of that annoying chime? |
(Post 17589482)
