rusty header bolts
Old Sep 11, 2003 | 10:37 AM
78f3504x4's Avatar
78f3504x4
rusty header bolts
I need to take off the right side headers to remove my cooked starter. Any tips you can give me on how to remove the rusty header bolts? I have a feeling they'll break off when I crank them off. A good soaking in WD-40?
Old Sep 11, 2003 | 12:09 PM
hillbillyk's Avatar
hillbillyk
rusty header bolts
I usually run the engine and let it get good and hot, then loosen them, has worked so far, just gotta watch them hot exhaust parts. or use pb blaster or something like that.
Old Sep 11, 2003 | 12:39 PM
Thudpucker's Avatar
Thudpucker
rusty header bolts
That's good advice. pre soak in Pblaster, Loosen when hot, and my own theory is this: If you start turning one of those bolts, keep going at the same rate till it's off.
In other words keep the air ratchet or the mechanical wrench going while you have the bolt moving.
If you let the bolt stop, it's so hot from friction, it will sieze in place, and then you'll twist it off when you start it up again.
Always use Air drivers when you can, and dont jazz the triggers.
Old Sep 11, 2003 | 03:43 PM
ranger429's Avatar
ranger429
rusty header bolts
how true that is
Old Sep 11, 2003 | 07:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
rusty header bolts
Try the candle trick.
Old Sep 11, 2003 | 10:35 PM
Mil1ion's Avatar
Mil1ion
rusty header bolts
Maybe he has a trouble light that will shine brighter
Old Sep 12, 2003 | 09:23 AM
78f3504x4's Avatar
78f3504x4
rusty header bolts
good advice, thanks
gopher2
20
Sep 18, 2013 08:17 PM
fash
May 21, 2010 12:54 PM
cjben
Aug 20, 2008 09:13 AM
offroaderone
Apr 6, 2004 11:02 PM
