Won't crank
Old Nov 11, 2017 | 04:11 PM
Mich6.0's Avatar
Mich6.0
Won't crank
2003 f250 will not crank with ignition switch but will crank with red wire on passenger side any help will be appreciated. Has FASS fuel pump system, new batteries. Could it be the FICM ? or PCM ? All fuses have been checked numerous times.
Old Nov 11, 2017 | 10:02 PM
navistarnut's Avatar
navistarnut
Could very well be the ignition switch itself
Will is actually start with the key in run, whilst cranking with starter wire?
Old Nov 11, 2017 | 10:18 PM
xcrsp440's Avatar
xcrsp440
Make sure it is in park. Wiggle the shifter a bit while turning the key.
Old Nov 12, 2017 | 11:52 AM
Mich6.0's Avatar
Mich6.0
Thanks for the info passed it on to my friend, he has nothing but problems with his truck , mostly self induced .
Old Nov 12, 2017 | 03:21 PM
duallydondon's Avatar
duallydondon
Stopped at gas station ,,2015 F250 with 6.2 would not crank wiggled gear shift lever several times, nada,,,went up and down the gear settings then tried again nada,,,got booster cables out , called son ,,,tried again and it started,,,anyone have an idea what could have caused issue???
Ddaybc
33
Jul 15, 2020 09:09 AM
truckiescott
Feb 20, 2017 07:20 PM
Daves94vert
Jul 23, 2014 09:09 PM
scottek
Jun 19, 2007 09:08 PM
MacFastStang
Feb 14, 2007 10:58 PM
