Cylinder not firing
Cylinder not firing
I have a 1990 F150 XLT Lariat with the 300 CI inline 6 cylinder EFI. I have owned the truck for almost 17 years with virtually no problems. The truck has 143,000 miles on it. Recently as I pulled up to a stop sign the truck started skipping. When I got back home and started pulling plug wires the number 1 cylinder wasn't firing. So far I have replaced all the plug wires, all the plugs and the fuel injector for that cylinder with no success. Any help will be greatly appreciated.
Cylinder not firing
Thanks for the comments everyone, sorry it has taken me so long to get back on here. I am getting fire thru both the plug wire and the plug, both of which are new. Since I was getting fire into the cylinder I figured the injector was bad so I replaced it. The cylinder is still dead. I haven't had a chance to do a compression check or to check voltage on the wires going to the injector. One thing I have noticed while test driving the truck is that the engine seems to smooth out about 35 mph. When running about 50 mph I floored the accelerator pedal and the truck down shifted and accelerated quickly, the engine sounded smooth and the power output from the engine felt normal. To say the least I'm at a loss.
Ok, did compression check on dead cylinder ( #1). With compression gauge installed, started the engine gauge went to 120PSI. When I mashed the release button the compression fluctuated from 65 to 70 PSI with the engine idling. To verify that this was correct readings I installed compression gauge in #4 cylinder, which is operating correctly, and got the exact same readings. I was going to do a voltage check on the wires going to the injector but my volt meter died, so hopefully I can pick one up tomorrow and check it. I did disconnect the wires from the injector on the #2 cylinder and it started missing on that cylinder. When I replugged the wires that cylinder went back to normal. Hopefully I'll know more when I get another volt meter tomorrow.
1975MudRat
10-18-2012 12:48 AM
WoomaHodal
03-16-2007 03:22 AM
