Depends on the 17-18. If the truck is an HD250 or 6.7 SRW350, then they would need new rear center caps because those two trucks use the new DANA M275 axle. Even then, I'm not sure if the center bore is larger too? I'd def check before going ahead with the swap. If the 17-18 is a 6.2 350 or standard 250, then yes they would be a direct swap over.
You'd need different rear center caps. I'd check the center hub diameter in both wheels before buying to make sure the center cap depth is the only difference.
