2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
pre 2017 wheels fitment to 17-18 models
Old 11-11-2017, 03:13 PM
Daveyf15096's Avatar
Daveyf15096
Daveyf15096 is offline
Will the wheels from a pre 2017 model super duty fit the new 17-18 models. What is the difference. Anyone know
Old 11-11-2017, 03:16 PM
System's Avatar
System
System is online now
Prolocutor
Received 1,201 Likes on 575 Posts
Depends on the 17-18. If the truck is an HD250 or 6.7 SRW350, then they would need new rear center caps because those two trucks use the new DANA M275 axle. Even then, I'm not sure if the center bore is larger too? I'd def check before going ahead with the swap. If the 17-18 is a 6.2 350 or standard 250, then yes they would be a direct swap over.
Old 11-11-2017, 03:58 PM
Daveyf15096
assuming 350 diesel 20 inch wheel pre 17 to 350 diesel 18 inch wheel post 17. I like one of the earlier wheel
Old 11-11-2017, 04:03 PM
System's Avatar
System
Prolocutor
You'd need different rear center caps. I'd check the center hub diameter in both wheels before buying to make sure the center cap depth is the only difference.
Old 11-11-2017, 08:01 PM
6.2caribou's Avatar
6.2caribou
6.2caribou is offline
This is a good reference site.
www.wheel-size.com
Old 11-11-2017, 08:13 PM
nbayless36's Avatar
nbayless36
nbayless36 is offline
Bolt pattern and hub bore are the same but the back spacing may be different I know the leaf sprung trucks had less back spacing
CJ Duggan
2017+ Super Duty
02-23-2020 08:34 AM
Robert S
06-14-2018 05:51 PM
johnson.jeff.a
36
08-18-2014 01:09 AM
bunchoftrucks
05-16-2014 08:12 PM
Quick Reply: pre 2017 wheels fitment to 17-18 models
