Ref. 75 F-150; I am seeing pictures of a weatherstrip glued to upper part
of the cab door. I do not see it in the Carpenter catalog....unless I missed it.
Upper Door Seal - (65" Long)
Item ID: D8TZ-1020518-PR I ordered from carpenter back in august anti rattles ,vent window rubber ,left and right(passenger) vent window locks,,,put in vent w
Upper Door Seal - (65" Long) rubber ,installed vent window ,went to put on locking vent window lever ,one was made in the USA the other was tiawan,both of them were left hand even though the taiwan # showed RH ,,,You have to watch Carpenter alot
My 75 F-150 never had upper door weatherstrips. The long one glued to the door frame seems to be enough.
2) D8TZ-1020518-A .. Upper Door Weatherstrip - 65" long / Right/Left is the same / Reproduced by Carpenter (I just looked at his 1967/79 online truck catalog).
Introduced in 1978, could be retrofitted to 1973/77's. Carpenter's part number: D8TZ-1020518-PR (pair).
