Oil change filter drain?
There are a few layers inside the filter. You have to punch far enough in to get through the second layer into the core. I do this and never have any come out the top when unscrewing. As other have said, let it drain for as long as needed. It's not quick but it's clean.
Received 6,693 Likes
on
I always break the filter loose first before punching the hole. Just to be safe. Then after draining it for a little bit, loosen the filter enough you get air flowing into the top of it. You'll get some run down the side, but not much. The oil cooler drains too, so it's more oil coming out than just what the filter holds.
I skipped the hole punch this last time just to see how much time it would save. Didn't spill anything, but the oil rushing over all sides of the filter made for a slippery situation where an spill would happen sooner or later. I'll stick to the hole and have a beer while it drains method from now on.
Just did mine today. I poked a hole in bottom of filter and let it drain till it stopped. Then poked hole deeper into filter and about the same amount of oil ran out of filter. Unscrewed filter and was dry, and clean as could be. Will do it this way from now on.
Dave
Dave
dalfollo
1997-2006 Expedition & Navigator
03-16-2004 08:11 AM
